Livolo setup
twinsen
Livolo setup
#1 Post by twinsen » 16 Dec 2016, 11:23
I try to setup a Livolo dimmer switch to send DimUP and Dimdown command but I don't know that are the sintax.
In the user guide for small remote it says:
"For dimmer switch, after synchronizing the remote, the function ofthe buttons are as follows: A-On, B—. Dim Up, C—Dim Down, D—off"
In this case how I will simutate the B and C buttons function ?
I use domoticz and i have RFLink Version 43.4
 2016-12-16 12:19:22.145 RFLink Sending: 10;Livolo;00dd00;1;ON
2016-12-16 12:19:24.739 (RFLink) Light/Switch (Unknown)
 2016-12-16 12:19:20.016 RFLink Sending: 10;Livolo;00dd00;1;OFF
2016-12-16 12:19:21.310 (RFLink) Light/Switch (Unknown)
 2016-12-16 12:18:54.530 RFLink Sending: 10;Livolo;00dd00;1;12
2016-12-16 12:18:54.606 Error: RFLink: Error/Unknown command received!...
2016-12-16 12:18:54.606 (RFLink) Light/Switch (Unknown)
twinsen
Re: Livolo setup
#2 Post by twinsen » 17 Dec 2016, 23:38
No response... :(
Can someone tell me that is the sintax for livolo switch, please
10;Livolo;004000;8;on
What and which are the parameters
Last one is only on/off?
Stuntteam
Site Beheer
Re: Livolo setup
#3 Post by Stuntteam » 18 Dec 2016, 01:30
We currently only have ON/OFF.
It would be possible to add dimming functionality.
However, this does not work well with home automation software since there is no way to know the actual brightness level.
springfield
Re: Livolo setup
#4 Post by springfield » 08 Jan 2017, 17:41
Is a curtain switch also supported? Which is basicly an on/off for up/down.
icibt
Re: Livolo setup
#5 Post by icibt » 07 Feb 2017, 16:06
Stuntteam wrote:We currently only have ON/OFF.
As far as I understand Livolo has only Toggle + GroupOff functionality. There is some mention of Scenes here https://forum.arduino.cc/index.php?topic=153525.150, they mention that with that they now have true ON/OFF compatibility. But that maybe only for the Dimmer switch. I am also unsure how to add a switch in Domoticz for GroupOff. Can you help?
Manualy adding a swtich for Livlo works as Toggle switch without problems.
