mhouse, moovo and Nice protocol
Post here about devices that are not yet or not fully supported
JRCondat
#1 Post by JRCondat » 08 Dec 2016, 13:14
Hi,I have a garden gate with a mhouse motor (Nice, mhouse
and moovo use the same code transmission) but Domiticz and RFlink will autodetect the push on the original remote. But it doesn't work when I use the switch button on Domoticz.
They work on the 433,92MHz band
Look below there is a dump for 2 attemps because it's a rolling code.
20;00;Nodo RadioFrequencyLink - RFLink Gateway V1.1 - R45;
10;version;
20;01;VER=1.1;REV=45;BUILD=09;
10;status;
20;02;STATUS;setRF433=ON;setNodoNRF=OFF;setMilight=OFF;setLivingColors=OFF;setAnsluta=OFF;setGPIO=OFF;setBLE=OFF;setMysensors=OFF;
10;rfdebug=on;
20;03;RFDEBUG=ON;
20;04;DEBUG;Pulses=156;Pulses(uSec)=0,690,270,330,300,330,300,330,270,330,270,330,270,330,300,330,300,330,270,330,270,330,300,3900,690,330,270,720,300,720,690,330,300,720,720,330,270,720,720,330,720,330,300,720,690,330,720,330,720,330,300,720,690,330,690,330,270,720,720,330,690,330,300,720,270,750,690,330,300,720,690,330,690,330,720,330,270,720,720,330,690,330,690,330,690,330,720,330,720,330,690,330,300,750,270,750,690,330,720,330,300,720,690,330,270,750,690,330,300,720,720,330,300,720,690,330,690,330,270,720,300,720,300,720,690,330,270,750,690,330,690,330,690,330,690,330,690,330,690,330,720,330,690,330,690,330,270,750,690,330,690,330,300,720,300,6990;
20;05;DEBUG;Pulses=154;Pulses(uSec)=360,330,270,330,270,330,270,330,270,330,270,330,270,330,270,330,270,330,300,330,270,3900,690,330,270,720,270,750,690,330,270,720,690,330,270,720,690,330,690,330,270,720,690,330,690,330,690,330,270,720,690,330,690,330,270,720,690,330,690,330,270,720,270,720,690,330,270,720,690,330,690,330,690,330,270,720,690,330,690,330,690,330,690,330,690,330,690,330,690,330,300,720,270,750,690,330,690,330,300,720,690,330,270,750,690,330,270,720,690,330,270,720,690,330,690,330,270,720,300,720,270,720,690,330,270,750,690,330,690,330,690,330,690,330,690,330,690,330,690,330,690,330,690,330,270,750,690,330,690,330,690,330,270,6990;
20;06;Keeloq;ID=32a9;SWITCH=04;CMD=ON;BAT=OK;
10;rfdebug=off;
20;07;RFDEBUG=OFF;
10;rfdebug=on;
20;08;RFDEBUG=ON;
20;09;DEBUG;Pulses=156;Pulses(uSec)=390,330,300,330,300,330,300,330,300,330,300,330,300,330,300,330,300,330,300,330,300,330,300,3900,720,330,300,720,720,330,300,720,300,720,300,720,300,720,300,720,300,720,300,720,300,720,300,720,720,330,690,330,720,330,300,720,720,330,300,720,300,720,720,330,300,720,300,720,720,330,300,720,720,330,720,330,720,330,300,720,300,720,300,720,720,330,300,720,720,330,720,330,300,720,300,720,690,330,690,330,300,720,720,330,300,720,720,330,300,720,720,330,300,720,720,330,720,330,300,720,300,720,300,720,690,330,300,720,690,330,720,330,690,330,690,330,720,330,690,330,720,330,690,330,690,330,300,720,720,330,720,330,300,720,300,6990;
20;0A;Keeloq;ID=32a9;SWITCH=04;CMD=ON;BAT=LOW;
20;0B;DEBUG;Pulses=156;Pulses(uSec)=360,330,300,330,300,330,270,330,300,330,300,330,300,330,300,330,300,330,300,330,300,330,300,3870,690,330,300,720,690,330,300,720,300,720,300,720,300,720,300,720,300,720,300,720,300,720,300,720,690,330,690,330,690,330,300,720,690,330,300,720,300,720,690,330,300,720,300,720,690,330,300,720,690,330,690,330,720,330,300,720,300,720,300,720,690,330,300,720,690,330,720,330,300,720,300,720,720,330,690,330,300,720,690,330,300,720,720,330,300,720,690,330,300,720,690,330,720,330,300,720,300,720,300,720,720,330,300,720,720,330,720,330,690,330,690,330,720,330,690,330,720,330,690,330,690,330,300,720,690,330,720,330,300,720,300,6990;
20;0C;DEBUG;Pulses=66;Pulses(uSec)=360,330,300,330,300,330,300,330,300,330,300,330,300,330,300,330,300,330,300,330,300,330,300,3900,690,300,300,720,690,330,300,720,300,720,270,720,300,720,300,720,300,720,300,720,300,720,300,720,720,330,690,330,720,330,300,720,720,330,300,720,300,720,690,330,300,720;
10;rfdebug=off;
20;0D;RFDEBUG=OFF;
20;0E;Keeloq;ID=32a9;SWITCH=0b;CMD=ON;BAT=LOW;
JRCondat
Re: mhouse, moovo and Nice protocol
#2 Post by JRCondat » 22 Dec 2016, 11:32
There is an Italian company uses a rolling code detector and uses it :
https://www.1control.it/
Stuntteam
Site Beheer
#3 Post by Stuntteam » 22 Dec 2016, 16:06
For the Keyloq protocol we only support the receiv function.
If you want to have transmit, you need to know the key that is used to encrypt the rolling code. Meaning you need to hack the remote.
