Wayne Dalton Push pull garagedoor
Post here about devices that are not yet or not fully supported
JRCondat
#1 Post by JRCondat » 08 Dec 2016, 13:10
I have following setup from Wayne Dalton
- Push pull garagedoor openener
They work on the 433,92MHz band
However Domoticz doesn't see the signal at all when I press a button on these remotes but using RFlink Loader there is a dump for 2 attemps because it's a rolling code.
20;00;Nodo RadioFrequencyLink - RFLink Gateway V1.1 - R45;
10;version;
20;01;VER=1.1;REV=45;BUILD=09;
10;status;
20;02;STATUS;setRF433=ON;setNodoNRF=OFF;setMilight=OFF;setLivingColors=OFF;setAnsluta=OFF;setGPIO=OFF;setBLE=OFF;setMysensors=OFF;
10;rfdebug=on;
20;03;RFDEBUG=ON;
20;04;DEBUG;Pulses=42;Pulses(uSec)=450,1500,330,990,840,990,840,990,840,990,870,990,840,480,1350,1500,330,990,840,510,1350,990,840,480,1350,480,1350,510,1350,990,840,480,1350,1500,330,1500,330,1500,330,1500,330,6990;
20;05;DEBUG;Pulses=42;Pulses(uSec)=1440,1050,810,540,1320,1530,330,1020,840,1500,330,1020,840,1530,300,540,1320,1020,810,510,1320,1020,840,1020,840,510,1320,1530,300,1530,300,510,1350,1530,300,510,1320,1020,810,1530,300,6990;
20;06;DEBUG;Pulses=42;Pulses(uSec)=450,1530,300,1020,840,1020,810,1020,840,1020,810,1020,810,510,1320,1560,270,1020,810,510,1320,1020,810,510,1350,510,1320,510,1320,1020,840,540,1320,1530,300,1530,330,1530,330,1530,300,6990;
20;07;DEBUG;Pulses=42;Pulses(uSec)=1470,1020,810,510,1320,1530,330,1020,810,1530,300,1020,840,1530,300,510,1350,1020,840,510,1320,1020,840,1020,810,540,1290,1560,300,1530,300,510,1350,1530,300,510,1320,1020,840,1530,300,6990;
20;08;DEBUG;Pulses=42;Pulses(uSec)=450,1530,330,1020,810,1020,810,1020,840,1020,810,1020,810,510,1350,1530,330,1020,810,510,1320,1020,840,540,1320,510,1320,510,1320,1020,840,510,1320,1530,300,1530,300,1530,330,1530,330,6990;
20;09;DEBUG;Pulses=42;Pulses(uSec)=1470,1020,810,510,1320,1530,330,1020,810,1530,300,1020,810,1530,330,510,1350,1020,840,510,1350,1020,810,1020,810,510,1350,1530,300,1530,330,510,1320,1530,330,510,1320,1020,840,1530,300,6990;
20;0A;DEBUG;Pulses=42;Pulses(uSec)=450,1530,300,1020,810,1020,810,1020,810,1050,810,1020,840,510,1350,1530,300,1020,810,510,1320,1020,840,510,1320,510,1350,510,1320,1020,840,510,1350,1560,300,1530,300,1530,300,1530,300,6990;
20;0B;DEBUG;Pulses=42;Pulses(uSec)=1470,990,840,480,1350,1500,330,990,840,1500,330,990,840,1500,330,480,1350,990,840,480,1350,990,840,990,840,480,1350,1470,360,1470,360,480,1380,1500,360,480,1350,990,870,1470,360,6990;
10;rfdebug=off;
20;0C;RFDEBUG=OFF;
10;rfdebug=on;
20;0D;RFDEBUG=ON;
20;0E;DEBUG;Pulses=42;Pulses(uSec)=450,990,870,450,1380,990,840,480,1380,990,870,480,1350,1500,360,480,1380,990,870,990,840,990,870,990,840,1500,330,480,1350,480,1350,1500,360,990,840,480,1350,1020,810,1500,330,6990;
20;0F;DEBUG;Pulses=42;Pulses(uSec)=1470,1530,330,990,840,480,1350,480,1350,1500,330,510,1350,510,1350,510,1350,1020,840,510,1350,1500,330,1500,330,1020,840,990,840,510,1350,510,1350,1500,330,480,1350,510,1320,1020,840,6990;
20;10;DEBUG;Pulses=42;Pulses(uSec)=450,1020,810,480,1350,1020,810,480,1350,1020,810,510,1350,1500,330,510,1320,990,840,1020,840,990,840,1020,810,1500,330,510,1350,510,1320,1500,330,1020,840,480,1350,1020,810,1500,330,6990;
20;11;DEBUG;Pulses=42;Pulses(uSec)=1470,1530,330,1020,810,510,1350,510,1320,1500,330,480,1350,510,1320,510,1350,990,840,510,1350,1530,330,1500,330,990,840,1020,840,510,1350,510,1320,1530,300,510,1350,510,1350,990,840,6990;
20;12;DEBUG;Pulses=42;Pulses(uSec)=450,1020,810,510,1320,1020,810,510,1320,1020,810,510,1320,1530,330,510,1320,1020,810,1020,810,1020,810,1020,810,1530,330,510,1320,510,1350,1530,300,1020,840,510,1320,1020,810,1530,300,6990;
20;13;DEBUG;Pulses=42;Pulses(uSec)=1470,1500,330,1020,840,480,1350,510,1350,1500,330,510,1320,510,1350,510,1350,990,840,480,1350,1500,330,1500,330,990,840,990,840,480,1350,480,1350,1500,330,480,1350,480,1350,990,840,6990;
20;14;DEBUG;Pulses=42;Pulses(uSec)=450,960,870,480,1380,960,870,450,1380,960,870,480,1380,1470,360,450,1380,960,870,990,840,990,840,960,870,1470,360,450,1380,450,1380,1470,360,960,870,450,1380,960,870,1470,360,6990;
20;15;DEBUG;Pulses=42;Pulses(uSec)=1500,1470,360,960,870,450,1380,450,1380,1470,360,450,1380,450,1380,450,1380,960,870,450,1380,1470,360,1470,360,960,870,960,870,450,1380,480,1380,1470,360,450,1380,450,1380,960,870,6990;
10;rfdebug=off;
20;16;RFDEBUG=OFF;
serrnovik
Re: Wayne Dalton Push pull garagedoor
#2 Post by serrnovik » 26 May 2020, 22:50
Did you found a solution since original post?
I have the same issue. I've managed to do the same with different gates that are also use rolling code. But here the question is what protocol and what commands.
