weather station Aercus WS3083 ~= Fineoffset WA2080
Post here about devices that are not yet or not fully supported
polopolo92
#1 Post by polopolo92 » 27 Oct 2016, 17:32
I have a weather station Aercus WS3083 ( http://www.aercusinstruments.com/aercus ... r-station/ ) which seems to be equivalent more or less to FineOffset WA2080 ( http://www.foshk.com/Weather_Professional/WA2080.html )
I used it trough weewx connected to USB display but I would like to use it directly with RFLINK.
It recognized and identified with protocol "DKW2012" but only temperature is corresponding to the right value.
other one seem wrong (wind direction, wind speed, wind gust, humidity, rain) or missing (pressure, solar radiations, UV, rain/hour)
question :
- is it possible to test with another proctocol (how ?)
- what to provide to have a chance to add it in future releases of firmware ( I do not find the protocol doucmentations but I have the decoded value in weewx database)
thanks
Stuntteam
Site Beheer
Re: weather station Aercus WS3083 ~= Fineoffset WA2080
#2 Post by Stuntteam » 27 Oct 2016, 17:44
We need debug data from RFlink.
How to get that is explained here: http://www.nemcon.nl/blog2/development
Including the values that should be transmitted (values read from the Aercus display at the moment the debug packet appears)
Preferably for a few different readings.
Post data here or mail to frankzirrone@gmail.com
You can also mail in case something is not clear.
polopolo92
#3 Post by polopolo92 » 27 Oct 2016, 18:22
hello here are data :
20;00;Nodo RadioFrequencyLink - RFLink Gateway V1.1 - R43;
10;version;
20;01;VER=1.1;REV=43;BUILD=0a;
20;02;Oregon TempHygro;ID=2DE1;TEMP=80c3;HUM=49;HSTATUS=0;BAT=OK;
20;03;Alecto V4;ID=5b69;TEMP=00da;HUM=54;
10;rfdebug=on;
20;04;RFDEBUG=ON;
20;05;DEBUG;Pulses=128;Pulses(uSec)=420,930,360,960,360,930,360,930,360,960,360,930,360,930,360,960,1320,930,360,930,360,930,360,960,1320,930,360,930,360,960,1320,930,1320,930,360,960,1320,930,360,960,1320,930,1320,930,1320,930,1320,930,1320,930,360,960,1320,930,360,930,1320,930,360,930,1320,930,360,930,1320,930,1320,930,1320,930,1320,930,1320,930,1320,930,1320,930,1320,930,1320,930,360,960,1320,930,1320,930,360,930,360,930,360,930,360,960,360,930,360,960,1320,930,1320,930,360,960,1320,930,360,960,360,960,1320,930,360,930,1320,960,1320,930,1320,930,360,930,360,960,1320,6990;
20;06;Alecto V5;ID=0065;TEMP=813b;RAIN=ed00;BAT=OK;
20;07;DEBUG;Pulses=128;Pulses(uSec)=450,930,360,930,360,930,360,930,360,930,360,930,360,930,360,960,1320,930,360,930,360,930,360,960,1320,930,360,930,360,960,1320,930,1320,930,360,960,1320,930,360,930,1320,930,1320,930,1320,930,1320,930,1320,930,360,930,1320,930,360,960,1320,930,360,960,1320,930,360,960,1320,930,1320,930,1320,930,1320,930,1320,930,1320,930,1320,930,1320,930,1320,930,360,960,1320,930,1320,930,360,960,360,930,360,930,360,960,360,930,360,960,1320,930,1320,930,360,960,1320,930,360,930,360,960,1320,930,360,960,1320,930,1320,930,1320,930,360,930,360,960,1320,6990;
20;08;Alecto V5;ID=0065;TEMP=813b;RAIN=ed00;BAT=OK;
20;09;DEBUG;Pulses=176;Pulses(uSec)=390,930,420,930,390,930,420,930,390,930,420,930,390,930,420,930,390,930,1380,930,390,930,1380,930,1380,930,1380,930,420,930,1380,930,1380,930,1380,930,420,930,1380,930,1380,930,1380,930,420,930,1380,930,1380,930,1380,930,420,930,1380,930,390,930,420,930,420,930,420,930,1380,930,390,930,1380,930,1380,930,1380,930,420,930,1380,930,1380,930,1380,930,1380,930,1380,930,1380,930,1380,930,1380,930,1380,930,1380,930,1380,930,1380,930,1380,930,1380,930,1380,930,1380,930,1380,930,420,930,1380,930,1380,930,1380,930,1380,930,420,930,1380,930,1380,930,1380,930,420,930,390,930,420,930,390,930,1380,930,420,930,420,930,1380,930,1380,930,1380,930,1380,930,1380,930,1380,930,1380,930,1380,930,1380,930,390,930,1380,930,1380,930,420,930,420,930,420,930,1380,930,1380,6990;
20;0A;DKW2012;ID=0022;TEMP=009f;HUM=44;WINSP=0000;WINGS=000a;RAIN=08f6;WINDIR=0000;
20;0B;DEBUG;Pulses=234;Pulses(uSec)=990,870,900,870,900,870,900,870,900,870,900,870,900,870,900,870,900,870,900,870,900,870,900,870,900,870,900,870,900,870,900,360,420,870,390,390,900,390,390,870,420,360,900,870,900,390,420,870,900,870,900,870,420,390,900,360,420,870,390,390,900,870,900,390,420,870,390,390,900,390,420,870,900,870,900,870,900,870,900,870,900,870,390,390,900,360,420,870,900,870,900,870,390,390,900,390,390,870,900,870,900,870,900,870,420,390,900,870,900,870,900,870,900,360,420,870,900,870,900,870,420,390,900,390,390,870,420,390,900,390,390,870,420,360,900,390,420,870,900,870,390,390,900,870,900,360,420,870,900,870,900,870,900,870,900,870,900,870,390,390,900,870,900,390,390,870,900,870,390,390,900,360,420,870,900,870,390,390,900,390,390,870,900,870,900,870,900,870,900,870,390,390,900,390,420,870,390,390,900,360,420,870,900,870,900,870,420,390,900,390,390,870,420,360,900,390,390,870,900,870,900,870,900,870,390,390,900,360,420,870,900,870,240,6990;
20;0C;Oregon TempHygro;ID=2DE1;TEMP=80c3;HUM=49;HSTATUS=0;BAT=OK;
20;0D;DEBUG;Pulses=78;Pulses(uSec)=60,390,390,510,510,1860,390,3810,390,1860,420,3810,390,3810,390,1860,420,3810,390,3810,390,1860,390,3810,390,3810,390,1860,420,3810,390,1860,390,1860,390,3810,390,1860,390,1860,420,1860,390,1860,390,3810,420,3810,390,1860,420,3810,420,3810,390,1860,390,3810,390,1860,390,1860,420,1860,390,3810,390,3810,390,1860,390,3810,390,3810,420,1860,390,6990;
20;0E;Alecto V4;ID=5b69;TEMP=00da;HUM=54;
20;0F;DEBUG;Pulses=74;Pulses(uSec)=510,1860,390,3810,390,1860,390,3810,420,3810,390,1860,390,3810,390,3810,390,1860,390,3810,420,3810,420,1860,390,3810,390,1860,390,1860,390,3810,420,1860,390,1860,390,1860,390,1860,390,3810,390,3810,420,1860,390,3810,390,3810,390,1860,390,3810,390,1860,390,1860,390,1860,420,3810,390,3810,390,1860,420,3810,420,3810,390,1860,390,6990;
20;10;DEBUG;Pulses=46;Pulses(uSec)=120,1770,360,3630,390,1740,360,1830,390,1860,420,1860,390,3810,390,3810,420,1860,390,3810,390,3810,390,1860,420,3810,390,1860,390,1860,390,1860,390,3810,390,3810,390,1860,390,3810,420,3810,390,1860,390,6990;
20;11;DEBUG;Pulses=58;Pulses(uSec)=450,1740,390,3630,360,3690,420,1860,390,3810,390,1860,420,1860,390,3810,390,1860,420,1860,390,1860,390,1860,420,3810,390,3810,390,1860,420,3810,390,3810,390,1860,390,3810,390,1860,390,1860,420,1860,390,3810,420,3810,390,1860,390,3810,390,3810,420,1860,390,6990;
20;12;DEBUG;Pulses=52;Pulses(uSec)=450,1740,360,3630,390,1830,390,1860,390,3810,390,1860,390,1860,420,1860,390,1860,390,3810,420,3810,390,1860,420,3810,390,3810,390,1860,420,3810,390,1860,390,1860,420,1860,420,3810,390,3810,420,1860,390,3810,390,3810,390,1860,390,6990;
20;13;DEBUG;Pulses=176;Pulses(uSec)=450,930,420,930,420,930,420,930,420,930,420,930,390,930,390,930,390,930,1380,930,420,930,1380,930,1380,930,1380,930,420,930,1380,930,1380,930,1380,930,420,930,1380,930,1380,930,1380,930,390,930,1380,930,1380,930,1380,930,420,930,1380,930,390,930,420,930,390,930,420,930,1380,930,420,930,1380,930,1380,930,1380,930,390,930,1380,930,1380,930,1380,930,1380,930,1380,930,1380,930,1380,930,1380,930,1380,930,1380,930,1380,930,1380,930,1380,930,1380,930,1380,930,1380,930,1380,930,420,930,1380,930,1380,930,1380,930,1380,930,420,930,1380,930,1380,930,1380,930,420,930,390,930,420,930,420,930,1380,930,390,930,420,930,1380,930,1380,930,1380,930,1380,930,1380,930,390,930,420,930,420,930,420,930,420,930,1380,930,390,930,420,930,1380,930,1380,930,420,930,1380,6990;
20;14;DKW2012;ID=0022;TEMP=009f;HUM=44;WINSP=0000;WINGS=000a;RAIN=08f6;WINDIR=0015;
20;15;DEBUG;Pulses=78;Pulses(uSec)=270,390,390,510,510,1860,390,3810,390,1860,420,3810,390,3810,390,1860,390,3810,390,3810,390,1860,390,3810,390,3810,390,1860,420,3810,390,1860,390,1860,390,3810,390,1860,390,1860,420,1860,390,1860,390,3810,420,3810,390,1860,420,3810,390,3810,390,1860,390,3810,420,1860,390,1860,420,1860,390,3810,390,3810,390,1860,420,3810,390,3810,420,1860,390,6990;
20;16;Alecto V4;ID=5b69;TEMP=00da;HUM=54;
20;17;DEBUG;Pulses=74;Pulses(uSec)=510,1860,390,3810,420,1860,390,3810,420,3810,390,1860,390,3810,390,3810,420,1860,390,3810,420,3810,390,1860,390,3810,390,1860,390,1860,390,3810,390,1860,390,1860,390,1860,420,1860,390,3810,390,3810,390,1860,390,3810,390,3810,420,1860,390,3810,390,1860,420,1860,390,1860,390,3810,420,3810,390,1860,420,3810,390,3810,390,1860,420,6990;
20;18;DEBUG;Pulses=46;Pulses(uSec)=120,1770,390,3600,360,1740,390,1800,390,1860,390,1860,390,3810,390,3810,420,1860,420,3810,390,3810,420,1860,390,3810,390,1860,420,1860,390,1860,390,3810,420,3810,390,1860,390,3810,390,3810,420,1860,390,6990;
20;19;DEBUG;Pulses=58;Pulses(uSec)=450,1740,360,3630,390,3690,390,1860,420,3810,390,1860,390,1860,420,3810,390,1860,390,1860,420,1860,390,1860,420,3810,390,3810,390,1860,390,3810,390,3810,390,1860,420,3810,420,1860,390,1860,390,1860,390,3810,390,3810,420,1860,390,3810,390,3810,420,1860,390,6990;
20;1A;DEBUG;Pulses=52;Pulses(uSec)=420,1740,390,3630,390,1830,390,1860,390,3810,420,1860,390,1860,390,1860,390,1860,420,3810,390,3810,390,1860,420,3810,420,3810,390,1860,390,3810,420,1860,390,1860,390,1860,390,3810,390,3810,390,1860,420,3810,390,3810,390,1860,420,6990;
20;1B;DEBUG;Pulses=234;Pulses(uSec)=930,870,900,870,900,870,900,870,900,870,900,870,900,870,900,870,900,870,900,870,900,870,900,870,900,870,900,870,900,870,900,390,420,870,390,390,900,390,420,870,390,390,900,870,900,390,420,870,900,870,900,870,420,390,900,390,390,870,390,390,900,870,900,390,420,870,390,390,900,360,420,870,900,870,900,870,900,870,900,870,900,870,420,360,900,390,390,870,900,870,900,870,390,390,900,390,420,870,900,870,900,870,900,870,420,390,900,870,900,870,900,870,900,390,420,870,900,870,900,870,390,390,900,390,390,870,390,390,900,390,390,870,420,390,900,390,390,870,900,870,420,390,900,870,900,390,420,870,900,870,900,870,900,870,900,870,900,870,420,360,900,870,900,390,390,870,900,870,390,390,900,390,420,870,900,870,390,390,900,360,420,870,900,870,900,870,900,870,900,870,420,390,900,390,390,870,420,390,900,390,420,870,900,870,870,870,390,390,900,390,390,870,420,360,900,390,390,870,900,870,900,870,900,870,390,390,900,390,420,870,900,870,150,5070;
20;1C;Oregon TempHygro;ID=2DE1;TEMP=80c3;HUM=49;HSTATUS=0;BAT=OK;
20;1D;DEBUG;Pulses=40;Pulses(uSec)=360,240,60,480,60,480,60,480,60,480,60,450,330,210,330,240,300,240,60,480,300,240,60,480,60,480,60,480,60,510,30,480,1020,960,810,960,810,960,780,720;
20;1E;DEBUG;Pulses=32;Pulses(uSec)=390,210,330,240,60,480,330,240,30,510,60,480,330,240,60,480,30,450,330,240,60,480,60,480,330,240,60,480,330,240,60,360;
20;1F;DEBUG;Pulses=26;Pulses(uSec)=840,900,750,930,30,450,60,450,270,210,270,210,60,360,390,240,60,450,30,450,300,240,60,480,60,90;
20;20;DEBUG;Pulses=23;Pulses(uSec)=120,450,60,450,30,480,30,450,960,900,750,930,750,900,750,960,810,630,360,510,30,210,420;
20;21;DEBUG;Pulses=53;Pulses(uSec)=0,1020,30,510,30,480,300,210,300,240,60,480,300,240,60,480,30,480,300,240,60,480,60,480,300,240,30,480,60,480,300,240,60,480,330,240,60,510,30,480,60,510,60,480,60,480,300,240,330,240,300,240,60;
20;22;DEBUG;Pulses=47;Pulses(uSec)=120,480,300,240,300,240,300,240,30,480,300,240,30,510,30,480,60,480,30,510,60,480,1050,960,810,960,810,960,780,960,810,990,30,510,60,480,330,210,330,240,60,480,810,480,30,90,510;
20;23;DEBUG;Pulses=72;Pulses(uSec)=1500,810,360,960,1320,930,360,960,1320,930,1320,930,1320,930,1320,930,1320,930,1320,930,1320,930,1320,930,1320,930,360,960,1320,930,1320,930,360,960,1320,930,360,960,1320,930,1320,930,1320,930,1320,930,360,930,360,960,1320,930,360,930,360,960,1320,930,1320,930,360,930,360,960,1320,930,360,960,1320,930,360,6990;
Aercus display
pressure : 1029 hpa
humidity : 68 %
temp 15.8 °C
wind dir 270° wind speed 0 wind gust 0
light 1738 lux
UV 0
rain 0mm
20;C3;DEBUG;Pulses=80;Pulses(uSec)=60,0,90,390,390,510,270,1860,390,3810,420,1860,390,3810,420,3810,390,1860,390,3810,390,3810,390,1860,390,3810,420,3810,420,1860,390,3810,420,1860,420,1860,390,3810,420,1860,390,1860,390,1860,420,1860,390,3810,420,3810,390,1860,390,3810,390,3810,420,1860,390,1860,390,3810,420,1860,390,1860,390,3810,420,3810,390,1860,420,3810,390,3810,390,1860,390,6990;
20;C4;DEBUG;Pulses=42;Pulses(uSec)=450,1740,390,1770,390,1770,420,1860,390,3810,390,3810,390,1860,420,3810,390,3810,420,1860,420,1860,390,3810,420,1860,390,1860,390,3810,420,3810,390,1860,390,3810,390,3810,420,1860,390,6990;
20;C5;DEBUG;Pulses=58;Pulses(uSec)=450,1770,360,3630,390,3810,390,1860,420,3810,390,1860,390,1860,420,3810,390,1860,390,1860,420,1860,390,1860,390,3810,390,3810,390,1860,390,3810,390,3810,390,1860,420,1860,390,3810,390,1860,420,1860,390,3810,390,3810,420,1860,390,3810,390,3810,390,1860,390,6990;
20;C6;DEBUG;Pulses=52;Pulses(uSec)=450,1740,390,3630,360,1860,390,1860,420,3810,390,1860,390,1860,420,1860,390,1860,420,3810,390,3810,390,1860,390,3810,420,3810,390,1860,390,1860,420,3810,390,1860,390,1860,390,3810,390,3810,390,1860,420,3810,390,3810,420,1860,420,6990;
20;C7;DEBUG;Pulses=54;Pulses(uSec)=450,3630,360,1770,360,3810,390,1860,390,1860,390,3810,390,1860,390,1860,420,1860,420,1860,390,3810,390,3810,420,1860,390,3810,420,3810,390,1860,390,1860,390,3810,420,1860,390,1860,390,3810,390,3810,390,1860,390,3810,420,3810,390,1860,420,6990;
20;C8;DEBUG;Pulses=54;Pulses(uSec)=210,3630,360,1770,360,3720,420,1860,420,1860,390,3810,420,1860,420,1860,390,1860,390,1860,390,3810,390,3810,390,1860,390,3810,390,3810,390,1860,390,1860,390,3810,390,1860,390,1860,420,3810,420,3810,390,1860,390,3810,390,3810,390,1860,390,6990;
20;C9;DEBUG;Pulses=56;Pulses(uSec)=330,930,360,930,360,930,360,960,360,930,360,930,360,960,360,960,1320,930,360,930,360,930,360,960,1320,930,360,930,360,960,1320,930,1320,930,360,960,1320,930,360,960,1320,930,1320,930,1320,930,1320,930,1320,930,360,960,1320,930,360,840;
20;CA;DEBUG;Pulses=38;Pulses(uSec)=420,900,1260,900,360,900,330,900,330,930,360,960,1320,930,1320,930,1320,930,1320,930,360,930,360,930,360,960,1320,930,1320,930,360,930,360,930,360,960,1320,6990;
20;CB;DEBUG;Pulses=120;Pulses(uSec)=420,900,330,900,330,900,330,900,1260,870,330,930,360,930,360,960,1320,930,360,930,360,960,1320,930,1320,930,360,960,1320,930,360,960,1320,930,1320,930,1320,930,1320,930,1320,930,360,960,1320,930,360,960,1320,930,360,960,1320,930,360,960,1320,930,1320,930,1320,930,1320,930,1320,930,1320,930,1320,930,1320,930,1320,930,1320,930,360,960,360,960,1320,930,360,960,1320,930,360,960,360,960,360,930,360,960,1320,930,1320,930,1320,930,1320,930,360,930,360,930,360,960,1320,930,1320,930,360,930,360,960,360,960,1320,5010;
20;CC;DEBUG;Pulses=60;Pulses(uSec)=690,900,1260,900,1260,900,1290,930,1320,930,1320,930,1320,930,1320,930,360,930,360,960,1320,930,360,960,1320,930,360,960,360,930,360,960,360,960,1320,930,1320,930,1320,930,1320,930,360,960,360,930,360,960,1320,930,1320,930,360,930,360,930,360,930,1320,1620;
20;CD;DEBUG;Pulses=176;Pulses(uSec)=480,930,420,930,420,930,420,930,420,930,420,930,420,930,420,930,390,930,1380,930,390,930,1380,930,1380,930,1380,930,390,930,1380,930,1380,930,1380,930,420,930,1380,930,1380,930,1380,930,390,930,1380,930,1380,930,1380,930,390,930,1380,930,420,930,420,930,1380,930,420,930,1380,930,420,930,1380,930,1380,930,1380,930,420,930,390,930,1380,930,1380,930,1380,930,1380,930,1380,930,1380,930,1380,930,1380,930,1380,930,1380,930,1380,930,1380,930,1380,930,1380,930,1380,930,1380,930,420,930,1380,930,1380,930,1380,930,1380,930,420,930,1380,930,1380,930,390,930,1380,930,1380,930,1380,930,390,930,1380,930,1380,930,420,930,1380,930,1380,930,1380,930,1380,930,1380,930,420,930,420,930,390,930,1380,930,1380,930,420,930,390,930,420,930,420,930,420,930,1380,930,420,6990;
20;CE;DKW2012;ID=0022;TEMP=009d;HUM=46;WINSP=0000;WINGS=000a;RAIN=0912;WINDIR=0014;
20;CF;DEBUG;Pulses=104;Pulses(uSec)=990,870,900,870,900,870,900,870,900,870,900,870,900,870,900,870,900,870,900,870,900,870,900,870,900,870,900,870,900,870,900,390,390,870,420,360,900,390,390,870,390,390,900,870,900,390,390,870,900,870,900,870,390,390,900,390,390,870,420,360,900,870,900,390,390,870,420,390,900,390,420,870,900,870,900,870,900,870,900,870,900,870,420,360,900,390,390,870,900,870,900,870,390,390,900,390,420,870,900,870,900,870,900,90;
20;D0;DEBUG;Pulses=42;Pulses(uSec)=600,810,390,360,840,360,360,840,840,840,900,870,900,870,390,390,870,390,420,870,390,390,900,870,900,390,390,870,900,870,900,870,900,870,420,360,900,390,390,870,150,2280;
20;D1;DEBUG;Pulses=230;Pulses(uSec)=870,870,900,870,900,870,900,870,900,870,900,870,900,870,900,870,900,870,900,870,900,870,900,870,900,870,900,870,900,870,900,390,420,870,420,360,900,390,390,870,390,390,900,870,900,390,390,870,900,840,930,870,390,390,900,360,420,870,390,390,900,870,900,390,390,870,390,390,900,390,390,870,900,870,900,870,900,870,900,870,900,870,390,390,900,360,420,870,900,870,900,870,420,360,900,390,390,870,900,870,900,870,900,870,390,390,900,870,900,870,900,870,900,390,420,870,900,870,870,870,900,870,420,390,870,390,390,870,900,870,390,390,900,360,390,870,900,870,390,390,900,870,900,390,420,870,900,870,900,870,900,870,900,870,900,870,390,390,900,870,900,390,420,870,900,870,390,390,900,390,390,870,900,870,420,390,900,390,390,870,900,870,900,870,900,870,900,870,900,870,390,390,900,360,420,870,900,870,900,870,900,870,420,390,900,390,390,870,390,390,900,870,900,390,420,870,900,870,900,870,900,870,420,390,900,390,390,870,240,3060;
20;D2;Oregon TempHygro;ID=2DE1;TEMP=80c0;HUM=49;HSTATUS=0;BAT=OK;
Pressure 1028.8 hpa
humidity 70%
temp. 15.7 °C
wind dir 280°C win sped / gust 0
rain 8.4 mm
light 1345 lux
UV 0
polopolo92
#4 Post by polopolo92 » 01 Nov 2016, 18:03
do you have all needed information to implement it ?
