Where to find information for 868MHz and hardware support?
I can't find it on the site.
Re: Where to find information for 868MHz and hardware support?
http://www.nemcon.nl/blog2/devlist
scroll down to the 868 mhz section.
Support for additional devices is under preparation.
If I remember well I did read somewhere that the firmware currently supports 868 MHz.
I therefore assumed that information about 868 MHz modules and wiring would be available, but info on 868 MHz supported devices would follow.
But I might have interpreted that incorrectly.
The firmware does indeed support 868mhz and some devices can be received when you use for example an Aurel 868mhz receiver/transceiver.
There is a pin compatible version of the aurel rtx mid working on 868 mhz.
Clear.
So that would be either 433MHz OR 868MHz supported on one gateway? (that would be a pity).
I have no use for 868MHz devices myself yet but it's good to know what is and is not possible.
Well.. that is an ASK/OOK module..
We are working on CC1100 and CC2500 support.. through SPI.. for 433, 868 and 2.4 ghz traffic.
There is always a way..
