SmartHome YC-4000B
Post here about devices that are not yet or not fully supported
ricotrotter
SmartHome YC-4000B
#1 Post by ricotrotter » 05 Sep 2016, 19:37
I am using a Smarthome YC-4000B and I am having stability issues on the reception of commandes:
Hereafter a debug log for repetitive presses of the A ON button:
20;04;DEBUG;Pulses=50;Pulses(uSec)=210,840,750,240,150,840,750,270,150,840,750,240,150,840,750,240,150,840,750,270,150,840,150,870,150,840,750,240,150,840,750,270,150,840,750,270,120,840,750,270,150,840,150,870,150,840,750,270,150,6990;
20;05;AB400D;ID=41;SWITCH=1;CMD=ON;
20;06;DEBUG;Pulses=50;Pulses(uSec)=270,840,750,240,150,840,750,270,150,870,720,270,150,840,750,240,150,840,750,240,150,870,150,840,150,840,750,240,150,840,750,240,150,840,750,270,150,840,750,240,150,870,150,840,150,840,750,270,150,6990;
20;07;AB400D;ID=41;SWITCH=1;CMD=ON;
20;09;DEBUG;Pulses=50;Pulses(uSec)=270,870,750,270,150,840,750,240,150,840,750,270,150,840,750,270,120,840,750,240,150,840,150,840,150,870,720,270,120,840,750,240,150,840,750,270,150,840,750,240,150,840,150,840,150,870,720,270,150,6990;
20;0A;AB400D;ID=41;SWITCH=1;CMD=ON;
20;0E;DEBUG;Pulses=50;Pulses(uSec)=300,870,750,240,150,840,750,270,150,870,750,240,150,840,750,270,150,840,750,270,120,840,750,270,150,840,750,270,150,870,720,270,150,870,720,240,150,840,750,270,750,270,750,270,750,270,750,270,150,6990;
20;0F;Eurodomest;ID=0aaaaa;SWITCH=00;CMD=ON;
Similarly, I never got the D Off button work. Hereafter log for D ON then D Off
20;9A;DEBUG;Pulses=50;Pulses(uSec)=210,840,750,240,150,870,720,270,150,840,750,240,150,840,750,240,150,840,750,270,150,870,750,270,150,870,750,240,150,840,750,240,150,840,150,870,120,840,750,240,150,870,150,840,150,840,750,270,150,6990;
20;9B;AB400D;ID=41;SWITCH=4;CMD=ON;
20;9C;DEBUG;Pulses=50;Pulses(uSec)=240,840,750,270,150,840,750,240,150,840,750,240,150,840,750,240,150,840,750,270,150,840,750,240,150,840,750,270,150,840,750,270,150,840,150,870,120,840,750,240,150,870,720,270,120,840,150,840,150,6990;
20;9D;Kaku;ID=50;SWITCH=16;CMD=OFF;
I have had this issue with R42. I am now using R43 - but it is the same behavior.
Any idea?
Rico
Stuntteam
Site Beheer
Re: SmartHome YC-4000B
#2 Post by Stuntteam » 05 Sep 2016, 23:02
R43 is not released. If you are using a test version then that might not address anything you are looking for, it might not even be a test version that can be used with jeedom/domoticz etc. but only to test some functionality..
Anyway, does your Smarthome remote have any dip switches?
ricotrotter
#3 Post by ricotrotter » 06 Sep 2016, 09:28
thanks for answer.
Point taken for R43: for now all the rest seem to keep on working (Alecto sensor, triggering the SmartHome plugs, movement sensor, using Jeedom...), if I have issues I will revert to R42.
Yes, it has dip switches: they are now all configured to Off (1,2, 3, 4 ,5).
I tried to change them to other configurations but I get the same result:
+ initially it works for A, B, C buttons, and, invariably, after ~30s - 1 min, it reverts to Eurodomest
+ it never works for D Off, I always get Kaku.
Rico
Stuntteam
Site Beheer
#4 Post by Stuntteam » 06 Sep 2016, 23:03
Check your mail..
Black8all
#5 Post by Black8all » 29 Jan 2019, 11:41
Hi, I know this post was a bit old, but I'm a beginner with domotic and RFLink and I've exactly the same error. Could you help me please?
