Is visonic power max 868Mhz supported??
Here is my log
http://pastebin.com/UsuHMzDc
Is normaly have several entries on debug mode per second? It is not normal in my 433 device, only in 868
About visonic:
http://www.visonic.com/spain/es/Product ... ct-234-wpp
MCT-234 ESPECIFICACIONES:
Frecuencias (MHz): 433.92 MHz ú 868.95, (especificar según necesidades)
Modulación: ASK (ON-OFF keying)
Duración de Transmisión: Cada botón al ser presionado causa una transmisión d hasta 2 seg.
Alimentación: Pila alcalina de 12 V. tipo GP23A o equivalente.
Visonic Power Max 868Mhz
Re: Visonic Power Max 868Mhz
It specifies this device as: Encoding: 28-bit ID, 4-bit and 32-bit function code jump.
I think this means the code changes every time you push a button. That is called a rolling code.
RFLink and most universal encoders/decoders cannot generate a rolling code.
Generating rolling codes is not needed to receive alarm system sensors.
So... Could be decoded Visonic 868Mhz by Rflink?
In theory, if RFLink has the right plugin, this code could be decoded.
That is, it would show you the 28 bit ID and probably the 4 bit function.
As far as I know, for now this plugin has not been written .
Hi all,
In Europe Visonic work over 868Mhz. How can help you to support this device? Is the code different with 433Mhz? I believe we only need to receive changes and we don't need rooling.
Thank you !!
Juanjo
Thank you !!
Juanjo
Has there been any progress in supporting Visonic 868MHz devices?
I bought my RFLink believing Visonic were already supported, but it seems not.
It would be really great if these devices could be supported.
Users browsing this forum: Ahrefs [Bot] and 33 guests
