I know it is possible to reset to system defaults by giving the 'reset' command via the serial interface.
ESP will then appear as ESP_0 just like a new flashed ESP.
Is it possible to reset the system by rules? For example if a switch at GPIO is pushed the reset will take place?
I can always add this feature to my system with a very small PIC processor, but if it can be done in the firmware
saves me space on my PCB.
Maybe a feature request?
thank you.
Reset to system defaults
- nonflammable
Re: Reset to system defaults
It should be possible.
Just add Switch Input in Devices.
Eg.
GPIO 14
Value Name: Switch
then in rules add:
on S1#Switch=1.00 do
reset
*for tests it's better change "reset" to "reboot"![Lach :)](./images/smilies/icon_e_smile.gif)
Eg.
GPIO 14
Value Name: Switch
then in rules add:
reset
[Solved] Reset to system defaults
I found a solution;
When connecting Tx and Rx together during bootup, it will bring ESP to it's virgin state. After that, you can see ESP_0 in your AP list and connect to it.
Could you please tell me how ?mgennip wrote:I know it is possible to reset to system defaults by giving the 'reset' command via the serial interface.
Re: [Solved] Reset to system defaults
Unfortunatly this doesn't work at home !!mgennip wrote:I found a solution;
On ESP board connect TX and RX together, power up the board and remove the TX RX shortcut. Flash will be erased, this takes some time, then ESP_0 will appear on your laptop's AP list.
