RFLink reception signal not stable
Posted: 17 Jun 2016, 21:00
Hi RFLinkers!
after an experience in the past with 433Mhz now tried the RFLink finally.
This works fine but the results are not always the same. I did build it with TX, RX and ESP ser2net. The basics works fine but the results are not always correct.
now removing parts to minimize the build.
Also tried with other power supply. same unstable results.
Tried the RF-5V and a 'super heterodyne" receiver. same results.
the only thing a didn't change was the arduino mega. So this can be the cause. should order another one to test.
So, i captured some traces when pressing the same button (on a 'ELRO AB440R' remote with diff DIP switch settings) with intervals. The results are not the same and this is annoying in domoticz to cover this. (If domoticz can cover this temporarily, please advice )
20;49;DEBUG;Pulses=48;Pulses(uSec)=630,480,330,720,300,750,270,750,900,180,240,780,870,180,240,810,840,210,210,810,840,210,210,840,840,210,210,840,810,240,210,840,180,840,180,840,810,240,180,870,780,240,180,870,180,840,180,6990;
20;4A;DEBUG;Pulses=50;Pulses(uSec)=270,840,210,840,210,840,180,840,210,840,810,240,180,840,810,240,180,840,810,240,180,840,810,240,180,870,780,240,180,870,780,240,180,870,180,870,180,870,780,240,180,870,780,240,180,870,150,870,180,6990;
20;4B;Kaku;ID=4d;SWITCH=16;CMD=OFF;
20;4C;DEBUG;Pulses=50;Pulses(uSec)=270,840,180,840,180,840,180,840,180,840,810,240,180,870,780,240,180,870,780,240,180,870,780,240,180,870,780,240,180,870,780,240,180,870,150,870,150,900,750,270,150,870,780,240,180,870,150,870,150,6990;
20;4D;DEBUG;Pulses=50;Pulses(uSec)=240,840,180,870,180,870,180,870,180,870,780,240,180,870,780,240,150,870,780,270,180,870,780,270,150,870,780,270,150,870,780,270,150,870,780,240,150,870,780,270,780,270,780,270,780,270,780,270,150,6990;
20;4E;DEBUG;Pulses=50;Pulses(uSec)=30,120,330,690,300,720,270,750,300,750,870,180,240,810,840,180,240,810,840,210,240,810,840,210,210,840,810,210,210,840,810,210,210,840,180,840,180,840,780,240,180,840,810,240,180,870,180,840,180,6990;
20;4F;DEBUG;Pulses=50;Pulses(uSec)=270,840,210,840,180,840,210,840,210,840,810,240,210,840,810,240,180,840,810,240,180,870,780,240,180,840,810,240,180,870,780,240,180,870,180,870,180,870,810,240,180,870,780,240,180,870,150,870,180,6990;
20;50;Kaku;ID=4d;SWITCH=16;CMD=OFF;
20;51;DEBUG;Pulses=50;Pulses(uSec)=270,870,180,840,180,840,180,840,180,870,780,240,180,870,780,240,180,870,780,240,180,870,780,240,180,870,780,270,180,870,780,240,150,870,150,870,180,870,780,270,150,870,780,270,150,870,150,870,150,6990;
20;52;DEBUG;Pulses=50;Pulses(uSec)=270,840,180,840,180,870,180,870,180,870,780,240,180,870,780,240,180,870,780,240,180,870,780,270,150,870,780,240,180,870,780,240,180,870,780,240,150,870,780,270,780,270,780,270,780,270,780,270,150,6990;
20;53;DEBUG;Pulses=50;Pulses(uSec)=810,390,300,720,270,750,300,750,270,750,870,180,240,780,870,180,240,810,840,210,210,810,840,210,210,840,810,240,180,840,810,240,180,840,210,840,180,840,810,240,180,840,810,240,180,870,180,840,180,6990;
20;54;Eurodomest;ID=07aaae;SWITCH=05;CMD=ALLON;
20;55;DEBUG;Pulses=50;Pulses(uSec)=270,840,180,840,180,870,180,840,180,840,810,240,180,870,780,240,180,870,780,240,180,870,780,270,150,870,780,270,150,870,780,240,180,870,150,870,150,870,780,270,150,900,750,270,150,900,150,900,150,6990;
20;56;Kaku;ID=4d;SWITCH=16;CMD=OFF;
20;57;DEBUG;Pulses=50;Pulses(uSec)=240,870,180,870,150,870,180,870,180,870,780,270,150,870,780,240,150,870,780,240,180,870,780,270,150,870,780,270,150,870,780,300,150,870,780,270,150,870,780,270,150,900,750,270,150,870,780,270,150,6990;
20;58;AB400D;ID=44;SWITCH=31;CMD=ON;
20;59;DEBUG;Pulses=48;Pulses(uSec)=390,660,270,750,270,750,240,780,870,180,240,810,840,180,240,810,840,210,210,840,840,210,210,840,810,240,180,840,810,240,180,840,180,840,180,840,780,240,180,840,810,240,180,870,180,870,180,6990;
20;5A;DEBUG;Pulses=50;Pulses(uSec)=270,840,180,840,180,840,180,840,210,840,810,240,180,870,810,240,180,870,780,240,180,870,780,240,150,870,780,240,180,870,780,270,150,870,150,870,180,870,780,270,150,870,780,270,150,870,150,870,150,6990;
20;5B;Kaku;ID=4d;SWITCH=16;CMD=OFF;
20;5C;DEBUG;Pulses=50;Pulses(uSec)=240,870,180,870,180,870,180,870,180,870,780,240,180,870,780,270,150,870,780,270,150,870,780,240,150,870,780,270,150,870,780,270,150,870,150,870,150,870,780,270,150,870,780,270,150,900,150,870,150,6990;
20;5D;DEBUG;Pulses=50;Pulses(uSec)=240,870,180,870,180,870,150,870,150,870,780,270,150,870,780,270,150,870,780,270,150,900,780,270,150,870,780,270,150,870,780,270,150,870,780,270,150,900,750,270,750,270,780,270,750,300,750,270,150,6990;
20;5E;DEBUG;Pulses=48;Pulses(uSec)=450,690,300,750,300,750,270,780,870,180,240,810,840,210,210,810,840,210,210,810,840,210,180,840,810,210,210,840,810,240,180,840,180,840,180,840,810,240,180,840,810,240,180,870,180,870,180,6990;
20;5F;DEBUG;Pulses=50;Pulses(uSec)=270,840,210,840,180,840,210,840,210,840,810,240,180,840,810,240,180,840,810,240,180,870,780,240,180,870,810,240,180,870,780,270,180,870,150,870,150,870,780,270,150,870,780,270,150,870,150,870,150,6990;
20;60;Kaku;ID=4d;SWITCH=16;CMD=OFF;
20;61;DEBUG;Pulses=50;Pulses(uSec)=240,870,180,870,180,870,180,870,180,870,780,240,180,870,780,270,180,870,780,270,150,870,780,270,150,870,780,270,150,870,780,270,150,870,150,870,150,900,780,270,150,870,780,270,150,900,150,870,150,6990;
20;62;DEBUG;Pulses=50;Pulses(uSec)=240,870,150,870,180,870,150,870,150,870,780,270,150,870,780,270,150,870,780,270,150,900,780,270,150,870,780,270,150,870,780,270,150,900,750,270,150,900,780,270,750,270,780,270,750,270,750,270,150,6990;
