Re: Asa zonwering
Posted: 19 Jun 2016, 22:51
by AndreM
hallo,
ASA heeft inderdaad een RTS signaal. Het is hetzelfde als somfy. (asa is een goedkopere variant van somfy).
Maar ik krijg mijn zonnewering niet gepaired met rflink.
Ik zag het volgende bericht op dit forum:
RTS problems in R42
Meld dit bericht
Citeer
Berichtdoor ono » 16 Jun 2016, 21:48
Thanks for a great product!
I have a lot of switches sensors that are controlled by RFLink. All works perfectly except my Somfy blind motors (Somfy 74300 blind (Smoove Origin)).
I have followed the guide:
https://matdomotique.wordpress.com/2016 ... -et-somfy/ and registered a second remote.
The blind does not pair with RFLink.
I have also tried the steps in this thread:
http://www.esp8266.nu/forum/viewtopic.php?t=873 without success.
I can see that the original remote is registered by RFLink (record 0).
10;rtsshow;
RTS Record: 0 Address: AF3B62 RC: 0148
RTS Record: 1 Address: 000000 RC: 0000
RTS Record: 2 Address: 000000 RC: 0000
RTS Record: 3 Address: 000000 RC: 0000
RTS Record: 4 Address: 000000 RC: 0000
RTS Record: 5 Address: 000000 RC: 0000
RTS Record: 6 Address: 000000 RC: 0000
RTS Record: 7 Address: 000000 RC: 0000
RTS Record: 8 Address: 000000 RC: 0000
RTS Record: 9 Address: 000000 RC: 0000
RTS Record: 10 Address: 000000 RC: 0000
RTS Record: 11 Address: 000000 RC: 0000
RTS Record: 12 Address: 000000 RC: 0000
RTS Record: 13 Address: 000000 RC: 0000
RTS Record: 14 Address: 000000 RC: 0000
RTS Record: 15 Address: 000000 RC: 0000
When I send commands using the orignal remote, the blind reacts as it should.
20;34;DEBUG;Pulses=84;Pulses(uSec)=2460,2430,2400,2430,4710,1170,1200,1200,1200,1170,1200,540,540,540,540,1200,540,540,540,540,1200,1200,1200,1200,1200,1200,540,540,540;
Debug a8eaeba30c3755
20;35;RTS;ID=af3b62;SWITCH=01;CMD=DOWN;
20;36;DEBUG;Pulses=92;Pulses(uSec)=2460,2430,2400,2430,4710,1200,1200,1200,1200,1200,1200,540,540,1200,540,540,1200,1200,540,540,540,540,540,570,540,540,1200,1200,1200,;
Debug a9bebff6596200
20;D5;DEBUG;Pulses=86;Pulses(uSec)=2460,2430,2400,2430,4710,1200,1170,1200,1200,1200,1200,1200,540,540,540,540,1200,540,540,540,540,1200,540,540,540,540,540,540,540,540;
Debug ab8f8ec56a5133
20;D6;RTS;ID=af3b62;SWITCH=01;CMD=UP;
10;rtsshow;
RTS Record: 0 Address: AF3B62 RC: 014C
I have tried: 10;RTS;AF3B62;0;DOWN;
and I have even tried to echo back the remote function (wild stab in the dark):
11;20;04;RTS;ID=af3b62;SWITCH=01;CMD=DOWN;
Nothing works.
RFLink seems to receive the signals correctly, but something fails when sending commands.
Why is debug information printed out before all the RTS commands (e.g Debug ab8f8ec56a5133)?
What am I doing wrong?
Any help is very much appreciated.
Regards,
ono
Is er sinds de update naar R42 echt een probleem met het zenden van RTS signalen?
Groeten
Re: Asa zonwering
Posted: 30 Jun 2016, 16:56
by AndreM
hallo,
bij deze de codes van de asa zonwering:
10;RTSSHOW
RTS Record: 0 Address: 144B38 RC: 006E
ZONWERING OMLAAG:
20;33;DEBUG;Pulses=98;Pulses(uSec)=2520,2520,2400,2520,4740,1200,1170,570,540,570,540,1200,1170,570,540,570,540,570,540,1200,540,570,540,570,540,570,540,570,540,570,1170,570,540,1200,540,570,540,570,540,570,540,570,540,570,1170,1230,510,570,510,570,1170,1200,540,570,510,570,540,570,540,570,540,570,540,570,540,570,540,570,1170,1200,540,570,510,570,1170,1200,510,570,1170,570,510,570,540,570,540,1200,1170,570,540,570,540,1200,1170,570,540,570,540,6990;
Debug 887e7eeffbb088
20;34;RTS;ID=144b38;SWITCH=01;CMD=STOP;
ZONWERING STOP:
20;1E;DEBUG;Pulses=88;Pulses(uSec)=2460,2520,2400,2520,4740,1200,1170,570,540,570,540,570,540,1200,1170,1200,1170,1200,540,570,540,570,540,570,1170,570,540,1200,1170,1200,540,570,540,570,510,570,1200,570,540,1200,1170,570,510,570,540,570,540,570,540,570,510,570,540,1200,1170,570,510,570,540,1200,1170,1200,1170,1200,1170,1200,1170,1200,540,570,540,570,540,570,1170,570,540,1200,540,570,1170,570,540,1200,510,570,1170,6990;
Debug 85797901155e66
20;1F;RTS;ID=144b38;SWITCH=01;CMD=STOP;
ZONWERING OMHOOG:
20;31;DEBUG;Pulses=100;Pulses(uSec)=2490,2490,2430,2490,4740,1230,1170,570,540,570,510,570,540,1200,540,570,1170,570,540,1200,540,570,540,570,540,540,540,570,540,570,540,570,1170,1200,540,570,540,570,540,570,540,570,540,570,510,570,540,570,540,570,510,570,1200,1200,540,570,540,570,540,570,540,570,540,570,540,570,540,570,540,570,1170,1200,540,570,540,570,1170,1200,540,540,1200,570,540,570,540,570,540,1200,1170,570,540,570,540,1200,1170,570,510,570,540,6990;
Debug 867f7feffbb088
20;32;RTS;ID=144b38;SWITCH=01;CMD=STOP;
Ik hoop dat je mij hiermee verder kunt helpen.
Groeten,
