RFLink release 42 is available for download
Posted: 09 Jun 2016, 17:39
by Stuntteam
R42:
- New Device: Mi-Light/LimitlessLED/Applamp bridge functionality (2.4 Ghz, NRF24L01 with Milight wiring required)
- New Device: Hama SD-UN5-RF switch set
- New Device: Acurite Tower sensors
- New Device: Pollin PFR-130 Temperature & Rain meter
- New Device: Gaposa Blind/Shutter control (a.o. model QCT3S)
- New Device: Byron BY35 / BY301
- Added: Command "echo" function to auto create devices without the need of remote controls
- Added: Command "rtsrecclean 9" function to clean a single rolling code table entry
- Added: Command to invert the ON/OFF handling of the Tristate protocol
- Fixed: improved Atlantic MD-210R detection
- Fixed: improved DKW2012 detection to cover variations of the signal
- Fixed: Smarthome YC-4000B detection
- Fixed: improved RTS packet detection to prevent false positives
- Fixed: improved FA500 packet detection to prevent false positives
- Fixed: Modified X10 security sensor packet detection
- Fixed: Modified maximum humidity limit
- Fixed: Improved signal ARC detection
- Fixed: Chacon EMW200 detection
- Fixed: Nexa WST-512 detection
- Fixed: Oregon UV800
- Fixed: CM113 ID
- Added: Support for another MiLight remote variant
the download is available via our blog.
http://www.nemcon.nl/blog2
Re: RFLink release 42 is available for download
Posted: 09 Jun 2016, 19:11
by negan
Great thanks !
Stuntteam wrote:- Added: Command to invert the ON/OFF handling of the Tristate protocol
How do you use this command ?
Thank you.
Posted: 18 Jun 2016, 20:49
by Mediacj
negan wrote:Great thanks !
Thank you.
I would like to know that to
Although I suppose this is not available for the Livolo switches where on=off and off=on(for me at least)
thx
Posted: 26 Jun 2016, 23:19
by rkoppen
Can someone elaborate on this, does this mean that you do not need a bridge ? And is a NRF24L01 needed ? Where can I find more info ?
Posted: 27 Jun 2016, 00:40
by Stuntteam
Correct, if you have RFLink with a NRF24L01 wired for Milight you do not need any other bridge.
you can find all details on
www.nemcon.nl/blog2
the wiring page shows how to connect the NRF24L01
the Frequently Asked Questions page shows various other aspects about Milight
Posted: 27 Jun 2016, 13:38
by rkoppen
That sounds cool, I will be looking into this.
Edit: Never mind found it in the FAQ.
Now to order a milight
Posted: 06 Jul 2016, 09:34
by negan
Thank you.
Any help ?
Thank you
Posted: 12 Jul 2016, 18:00
by lukcinek22
Is there a possibility to use RF Link Loader with Arduino NANO instead Arduino Mega?
Best regards
Posted: 12 Jul 2016, 21:11
by Stuntteam
No, sorry. RFlink wont fit on a Nano.
Btw, an Arduino Mega can be bought for as low as 6 euros..
Posted: 12 Jul 2016, 22:05
by grz3
is there available any smaller version of arduino mega (like nano) which will RFLINK fit into?
Posted: 12 Jul 2016, 23:51
by Stuntteam
Maybe the Mega Pro mini, we did not test it though.
But why would you use a smaller version?
Posted: 13 Jul 2016, 01:03
by lukcinek22
Thx for answer Stuntteam
I think I need to buy one...
Best regards
Posted: 13 Jul 2016, 08:31
by rkoppen
I think the questions is aimed to get a smaller form factor. do you have any plans/ideas ?
Posted: 13 Jul 2016, 09:43
by negan
Why is my question avoided ?
Posted: 13 Jul 2016, 10:25
by Stuntteam
oops, not on purpose..
I think you were looking for the following commands:
10;TRISTATEINVERT=ON;
10;TRISTATEINVERT=OFF;
Not fully tested yet.
Note that when you turn invert on, ON becomes OFF and vice versa for ALL tristate devices.
Posted: 13 Jul 2016, 22:53
by TwoEasy
Hi guys! I encountered a problem when trying to ad milight!
It finds the milight remote very fast. But when I click to turn milight on or off it just says
"Error sending switch command, check device/hardware !" in domoticz. How do I solve this?
Posted: 13 Jul 2016, 23:48
by Voyager
You probably need a more recent Domoticz version
Posted: 14 Jul 2016, 13:00
by TwoEasy
Voyager wrote:You probably need a more recent Domoticz version
I am on
Version: 3.4834
Build Hash: 8398125
Compile Date: 2016-03-02 08:43:51
How do I get a more updated version?
Edit: Should I go for the beta?
3.5301 2016-07-14
(I am using a Raspberry pi 2 for domoticz)
Posted: 14 Jul 2016, 13:13
by Stuntteam
Yes, you will need beta..
Posted: 14 Jul 2016, 13:53
by TwoEasy
Stuntteam wrote:Yes, you will need beta..
Thanks, Im really liking rflink so far!
edit: Was super quick to switch to beta, and milight instantly worked! Thank you!
Posted: 04 Aug 2016, 22:09
by the cosmic gate
anny news/ update for the next release incl mysensors ?
Posted: 20 Aug 2016, 16:18
by iMartyn
Please can we get the source uploaded?
Even better, can you put it on github and not do random google drive releases?
The nrf2401 library that I think you're using has some bugs and I'd like to use the patched/fixed version. The Milight is unreliable with some nrf2401l transmitters because of this (I think) but I can't fix it because you're only sometimes releasing source.
Posted: 22 Aug 2016, 17:16
by Stuntteam
Posted: 05 Sep 2016, 11:43
by the cosmic gate
is there some update about the RFLink with MySensors intergration ?
Posted: 11 Sep 2016, 16:37
by Ger
Any news about R43 and or sourcode on github?
Posted: 11 Sep 2016, 19:39
by Stuntteam
Target is this week..
update 16/9: slightly delayed.. nearly done..
