General questions and observations
Posted: 09 Oct 2015, 09:41
I am a starter on this project.
Some things might sound strange but this is what I like to know.
I have flashed a ESP-01 with the R20 version.
In the sketch I provided the SSID and PASSWORD and I could connect to the ESP EASY controlpage after the upload with the browser.
I could change the Static IP address and Gateway and Submask and save it.
After a reboot I can connect to the control page again.
Strange but my IP scanner does not find the IP address which I assigned on 192.168.1.80
So I took an other ESP-01 and did the same.
After connection with the controlpage I assigned it to 192.168.1.81
After a reboot again IP address is not found by the IP scanner.
1] Is there a way that I can assign the Static IP address and Gateway and Submask in the sketch on forhand?
I looked for it but could not find it.
2] Is there a way to erase the current sketch on the ESP?
I attached a DHT11 to GPIO2 and changed the settings in the device section and submit.
reboot but no data available. Also serial monitor does not show the sensor is connected.
Thanks, Paco
Thanks, Paco
