Ventilation System and garage door.
Posted: 03 Apr 2016, 11:19
by remb0
I see my garage door that Have a Rolling code as a keeloq.
Would this Be possible to pair??
And a ithi daalderop / buva Stork ventilation System is that compatible?
Re: Ventilation System and garage door.
Posted: 05 May 2016, 14:37
by BertB
I think I have the same ventilator. Don't know what frequency it is working on, but the remote control is very good.
Posted: 17 Jun 2016, 12:44
by Stuntteam
Keeloq is using encrypted data. Without knowing the key (eg hacking the key out of the remote) we can not add pairing / transmission support.
Right now only reception of Keeloq is supported so you can for example turn on the garage lights when the door is opened with the original remote.
I thin kthe Daalderop/buva is using 868 mhz?
No way to implement it due to missing hardware for testing.
Posted: 06 Feb 2020, 17:17
by akashkumar
I have a BFT remote, but it shows up as Keeloq when I press the button on the remote. As far as I can see, BFT is supported since v38 in RFLink. Is the protocol of BFT updated to another standard or can one use/buy different types of remote controls for BFT garage door opener?
Posted: 06 Feb 2020, 17:22
by Stuntteam
If it is recognized as Keeloq then you can receive but not transmit.
Posted: 19 Apr 2020, 14:43
by welverin
what do i need to be able to transmit?
to include the management of encrypted keys in the firmware on arduino?
sniffing the communication between the remote control and the garage door does not seem to send encrypted information, so the problem is only in the association between rflink and the bft controller as if it were a remote control? or I need dedicated hardware?
Leonardo
Posted: 19 Apr 2020, 15:08
by Stuntteam
You would need the decryption keys which you can not sniff from the signal. You could only get that by hacking the original hardware
Posted: 20 Apr 2020, 12:20
by welverin
thank's
ok i studied some of keeloq protocol
if i found the secret code to use, i will must insert in rflink code or can i use via serial console to pair my garage door with rflink ?
Posted: 20 Apr 2020, 14:55
by Stuntteam
RFlink needs to be adapted for it.
Contact me via mail.
Posted: 21 Apr 2020, 00:23
by welverin
ok thanks
i'll stay in touch
Leo
Posted: 28 May 2020, 12:28
by serrnovik
Also having the same thing with garage door.
If you succeed could you please post how did you extract the key and how to use it after.
Posted: 28 May 2020, 14:29
by welverin
No, i had no time because work and family
I’ll try next mounth
