Solved: Temperature sensor problem AVIDSEN
Post here about devices that are not yet or not fully supported
srpropper
#1 Post by srpropper » 12 Mar 2016, 14:27
Before r38 and r39 versions, this temperature sensor worked well and detected i think as Mebus protocol (ex 20;. 31; Mebus; ID = c201; TEMP = 00cf;)
Now or not detected or believed to be a switch with protocol FA500
Paste capture codes when sending captured temperature.
10;RFUDEBUG=ON;
20;07;RFUDEBUG=ON;
20;08;DEBUG;Pulses=58;Pulses(uSec)=150,2340,360,1890,360,4470,360,1890,360,4440,360,4470,360,4470,360,4470,360,4470,360,1890,360,1890,360,4470,360,1890,360,1890,360,1890,360,1890,360,4470,360,4470,360,1890,360,1890,360,4470,360,1890,360,1890,360,1890,360,1890,360,4470,360,4470,360,4470,360,6990;
20;09;DEBUG;Pulses=38;Pulses(uSec)=390,1800,330,4260,330,1800,330,1890,360,1920,330,1890,360,4470,330,4470,330,1920,330,1890,330,4470,360,1890,330,1920,360,1890,330,1920,360,4470,330,4470,330,4470,330,6990;
20;0A;DEBUG;Pulses=46;Pulses(uSec)=150,4260,330,4230,330,4440,330,1920,330,1890,330,4470,330,1890,330,1890,360,1890,330,1890,360,4470,360,4470,330,1890,360,1890,330,4470,330,1920,330,1920,360,1890,330,1890,360,4470,360,4470,360,4470,330,6990;
20;0B;DEBUG;Pulses=42;Pulses(uSec)=390,4260,330,1830,360,1890,360,4470,330,1890,360,1890,360,1890,360,1890,360,4470,360,4470,360,1890,360,1890,360,4470,360,1890,360,1890,360,1890,360,1890,360,4470,360,4470,360,4470,360,6990;
20;0C;DEBUG;Pulses=44;Pulses(uSec)=420,4230,330,4290,360,1890,360,1890,360,4470,360,1890,360,1890,360,1890,360,1890,360,4470,360,4470,360,1890,360,1890,360,4470,360,1890,360,1890,360,1890,360,1890,360,4470,360,4470,360,4470,360,6990;
20;0D;DEBUG;Pulses=44;Pulses(uSec)=420,4230,330,4230,330,1890,360,1890,360,4470,360,1890,360,1890,360,1890,360,1890,360,4470,360,4470,360,1890,360,1890,360,4470,360,1890,360,1890,360,1890,360,1890,360,4470,360,4470,360,4470,360,6990;
20;0E;DEBUG;Pulses=44;Pulses(uSec)=390,4230,330,4230,330,1890,360,1890,360,4470,360,1890,360,1890,330,1890,360,1890,360,4470,360,4470,360,1890,330,1890,360,4470,360,1890,360,1890,360,1890,360,1890,360,4470,360,4470,360,4470,360,6990;
20;0F;DEBUG;Pulses=44;Pulses(uSec)=390,4230,330,4260,330,1890,330,1890,360,4470,330,1890,360,1890,330,1890,360,1890,360,4470,360,4470,360,1890,360,1890,330,4470,360,1890,360,1890,330,1890,360,1890,360,4470,360,4470,360,4470,360,6990;
20;10;FA500;ID=0000fffd;SWITCH=00;CMD=ON;
20;11;FA500;ID=0000fffd;SWITCH=00;CMD=ON;
20;12;DEBUG;Pulses=58;Pulses(uSec)=450,2370,360,1890,360,4470,360,1890,360,4440,360,4440,360,4440,360,4440,360,4440,360,1890,360,1890,360,4440,360,1890,360,1890,360,1890,360,1890,360,4440,360,4440,360,1890,360,1890,360,4440,360,1890,360,1890,360,1890,360,1890,360,4440,360,4440,360,4440,360,6990;
20;13;DEBUG;Pulses=38;Pulses(uSec)=420,1770,330,4230,360,1770,360,1890,360,1890,360,1890,360,4440,360,4440,360,1890,360,1890,360,4440,360,1890,360,1890,360,1890,360,1890,360,4440,360,4440,360,4440,360,6990;
20;14;DEBUG;Pulses=46;Pulses(uSec)=150,4230,330,4230,330,4440,360,1890,360,1890,360,4440,360,1890,360,1890,360,1890,360,1890,360,4440,360,4440,360,1890,360,1890,360,4440,360,1890,360,1890,360,1890,360,1890,360,4440,360,4440,360,4440,360,6990;
20;15;DEBUG;Pulses=42;Pulses(uSec)=420,4230,330,1800,360,1890,360,4440,360,1890,360,1890,360,1890,360,1890,360,4440,360,4440,360,1890,360,1890,360,4440,360,1890,360,1890,360,1890,360,1890,360,4440,360,4440,360,4440,360,6990;
20;16;DEBUG;Pulses=44;Pulses(uSec)=420,4230,330,4260,360,1890,360,1890,360,4440,360,1890,360,1890,360,1890,360,1890,360,4440,360,4440,360,1890,360,1890,360,4440,360,1890,360,1890,360,1890,360,1890,360,4440,360,4440,360,4440,360,6990;
20;17;DEBUG;Pulses=44;Pulses(uSec)=420,4230,330,4230,360,1860,360,1890,360,4440,360,1890,360,1890,360,1890,360,1890,360,4440,360,4440,360,1890,360,1890,360,4440,360,1890,360,1890,360,1890,360,1890,360,4440,360,4440,360,4440,360,6990;
20;18;DEBUG;Pulses=44;Pulses(uSec)=420,4230,360,4230,330,1860,360,1890,360,4440,360,1890,360,1890,360,1890,360,1890,360,4440,360,4440,360,1890,360,1890,360,4440,360,1890,360,1890,360,1890,360,1890,360,4440,360,4440,360,4440,360,6990;
20;19;DEBUG;Pulses=44;Pulses(uSec)=420,4230,360,4230,330,1860,360,1890,360,4440,360,1890,360,1890,360,1890,360,1890,360,4440,360,4440,360,1890,360,1890,360,4470,360,1890,360,1890,360,1890,360,1890,360,4440,360,4440,360,4440,360,6990;
Thanks in advance.
Stuntteam
Site Beheer
Re: Solved: Temperature sensor problem AVIDSEN
#2 Post by Stuntteam » 17 Jun 2016, 17:01
Should have been fixed with release 40 but made another small change now which will be in r43
