ESP32C6 as zigbee thermometer and repeater
kniazio
#1 Post by kniazio » 18 Jan 2025, 20:04
Maybe someone will be interested.
Firmware for the ESP32C6 module working as Zigbee with a DS18B20 thermometer. The module also works as a Router(Repeater). I am sharing two versions of the bin file
One supports one ds18b20 thermometer and the other 4 ds18b20 thermometers. The file should be uploaded to address 0x0.
Tested on esp32c6 xiao seeed.
zigbee_thermometer.7z
(351.44 KiB) Downloaded 19 times
Re: ESP32C6 as zigbee thermometer and repeater
#2 Post by Ath » 19 Jan 2025, 13:50
Is the source (and documentation) for this project available anywhere (preferably Github)?
kniazio
#3 Post by kniazio » 19 Jan 2025, 19:05
Ath wrote: 19 Jan 2025, 13:50 Is the source (and documentation) for this project available anywhere (preferably Github)?
https://community.home-assistant.io/t/z ... tor/763388
https://github.com/prairiesnpr/esp_zha_freezer_mon
bidrohini
#4 Post by bidrohini » 25 Jan 2025, 17:50
kniazio wrote: 18 Jan 2025, 20:04 Maybe someone will be interested.
Thanks for sharing. If you want, you can make a PCB like this. https://www.pcbway.com/project/sharepro ... 99132.html
This is an ESP32-C6-based development board that supports the three most prominent IoT communication protocols: Wi-Fi, Bluetooth, and Zigbee. You can set up Xbee communication in a convenient way similar to this.
