I'm using an ESP01 with an ultrasonic distance sensor JSN-SR04T.
Trigger at GPIO-2 D4;
Echo at GPIO-3 D9
First I used ESP_Easy_mega_20210223_normal_ESP8266_1M.bin and it worked for about 3 years but half of the measured values were 0 (Timing problem, only HC-SR04 was officially supported).
Now I want to change from "values read by human" to automatic notification and tried a new release which now supports JSN-SR04T.
But the last release working is ESP_Easy_mega_20220616_normal_ESP8266_1M.bin.
With any release younger than this, the measurment failed and the log shows: Echo too late, maximum distance exceeded.
It took a while to find a working release so bug fixing would be nice for anyone using a similar config.
Distance sensor not working with release 20220809 and later
Re: Distance sensor not working with release 20220809 and later
Can you make an issue for this on GitHub, otherwise this (valuable) info may get lost.
