[SOLVED] diymore AC/DC Power Supply ESP8266 WIFI Four-Way Relay Module ESP-12F Development Board
Posted: 10 Mar 2024, 15:05
by sincze
Anyone familiar with this board?
- relaisboard.JPG (147.37 KiB) Viewed 1910 times
https://www.diymore.cc/collections/tags ... ec5b&_ss=r
I was able to flash it with:
mega-20240229 (leap-build)
(Collection C) hoping to be able to revive it with
Serial MCU controlled switch.
However using the plugin with LC TECH (if that would be correct) at 9600 19200 115200 there is nu music in the relais. Powered the board via 5v externally.
Any suggestions?
Re: diymore AC/DC Power Supply ESP8266 WIFI Four-Way Relay Module ESP-12F Development Board
Posted: 10 Mar 2024, 16:31
by Ath
Looking at the components on the board, I'd expect the relays to be controlled directly via GPIO pins of the ESP, and that will probably be GPIO-12, 13, 14 and 16.
You can test that from the Tools page, sending command gpio,12,1 or gpio,12,0 etc. to switch a relay.
The LC-Tech plugin is designed to send serial commands to a LC-Tech relay board, that's, AFAIK, not equipped with an ESP processor, so can't run ESPEasy directly.
NB: When adding power to the board, please use 5V or the 7-30V input, to avoid dangerously high voltages from the mains lines
Posted: 10 Mar 2024, 16:35
The LC-tech plugin is intended to communicate with a separate microprocessor running its own firmware.
This board indeed doesn't seem to have such a co-processor so it looks like you might be able to just toggle some GPIO pin.
Just try to toggle GPIO pins and try not to use GPIO 6 - 11 as those are connected to flash.
See:
https://espeasy.readthedocs.io/en/lates ... on-esp8266
Posted: 10 Mar 2024, 17:14
by sincze
To be honest I started with the GPIO test before moving (reflashing) to
Collection-C to try the LC_Tech idea.
- relay-close.jpg (163.8 KiB) Viewed 1897 times
Through the command box I tried flipping from 0 to 1 and 1 to 0
gpio,0,1
gpio,1,1
gpio,2,1 (Blue light switches on ESP)
gpio,3,1
gpio,4,1
gpio,5,1 (set to 0 this enables LED D1)
gpio,12,1
gpio,13,1
gpio,14,1
gpio,15,1
gpio,16,1
Relais are not clicking. Power is through YwRobot at 10v DC.
From the board I can tap 5v 3,3V DC from the pins on the right side.
Reset button resets the device. Any other ideas ?
Posted: 10 Mar 2024, 17:33
by Ath
I've marked the 4 most likely pcb traces to control the relays.
You can use a multi-meter to track back to what GPIO pin they lead... (when the board is NOT powered on!)
- Screenshot - 10-03-2024 , 17_29_46.png (663.29 KiB) Viewed 1893 times
Posted: 10 Mar 2024, 17:39
by sincze
Ath wrote: ↑10 Mar 2024, 17:33
Tnx. I like the notes that hint to blue smoke
I also found this similar piece of machinery:
https://templates.blakadder.com/ESP12F_Relay_X4.html
That would indicate you guys were right from the beginning.
GPIO # Component
GPIO00 User
GPIO01 User
GPIO02 Led_i 1
GPIO03 User
GPIO04 User
GPIO05 Led_i 2
GPIO09 User
GPIO10 User
GPIO12 Relay 3
GPIO13 Relay 4
GPIO14 Relay 2
GPIO15 User
GPIO16 Relay 1
GPIO17 User
Posted: 10 Mar 2024, 17:43
That template is for an ESP32, you have a board with ESP8266
Posted: 10 Mar 2024, 17:44
by sincze
TD-er wrote: ↑10 Mar 2024, 17:43
You beat me to it, i corrected myself
Posted: 10 Mar 2024, 17:50
by chromo23
Looking at the pcb it seems that j5 needs to be bridged with j6 since the the connections from the relays only lead to j5 (ry1 to ry4)
Posted: 10 Mar 2024, 18:09
by sincze
chromo23 wrote: ↑10 Mar 2024, 17:50
- relay-close-fix.jpg (196 KiB) Viewed 1874 times
Ding ding ding .
After noticing
https://templates.blakadder.com/assets/ ... PIO15.webp
I bridged mine as well (no jumpers on my board... so jumper wires) probably need to solder some pins.
Then GPIO commands 12,13,14 work, for GPIO 16 another bridge is needed.
Strange delivery of hardware I must say.
Re: [SOLVED] diymore AC/DC Power Supply ESP8266 WIFI Four-Way Relay Module ESP-12F Development Board
Posted: 10 Mar 2024, 21:29
As GPIO-16 is used, you probably can't use deepsleep on this board.
Posted: 12 Mar 2024, 03:29
by ThomasB
It's a nice touch that the relay's I/O assignments are not factory connected. You can freely choose the GPIO from header pads p3 (J6) and/or P4 (J7). That keeps it flexible.
Posted: 12 Mar 2024, 08:36
by sincze
ThomasB wrote: ↑12 Mar 2024, 03:29
I agree on the flexibility part. Now I can use 2 relais and I2C sensors and a door sensor as well.
But they sell it as works with E-WLINK, but without these jumpers or pins I would not consider it "works with'.
Works With after modification that is.
