Hi!
I have read lots of forum data about PZEM004T v3.
Now I wonder about current status of hooking up numeric devices to just one esp.
As I want to monitor almost every circuit in my main distribution a single esp might be great solution.
Thanks for your thoughts.
Bart
several PZEM004T to esp or just one
Re: several PZEM004T to esp or just one
No advices?
Well as far as I know is this a modbus sensor.
So in theory you can have multiple connected to the same serial bus and each should be assigned an unique modbus address.
However I don't know for sure is the ESPEasy implementation of it does address the sensor at its specific address (or the standard "broadcast" address) and also how the modbus address should be set at the PZEM004T.
And if it can be set, will it be a persistent setting (thus still set after power cycle) ?
Thus I hoped someone may have experience with actually using multiple instances of this device on ESPEasy.
In theory it should be possible, but there are quite some "ifs".
Users browsing this forum: Ahrefs [Bot] and 29 guests
