ESPEASY Flasching and the first Wifi connection?
Posted: 15 Feb 2024, 10:11
I don't understand why, with ESPEASY, I always have problems obtaining a quick and simple first connection after flashing with ESPEASY Web.
Here's the link I used with Microsoft Edge. https://td-er.nl/ESPEasy/
After installation complete!, Logs & Console, Connect to Wifi, Configure Wi-Fi, Triyng to connect, nothing happend.
For example with Tasmota : https://tasmota.github.io/install/
I do not have this kind of problem.
Here some information from the console:
00:01:16.954 : (16288) Info : WD : Uptime 1 ConnectFailures 0 FreeMem 16424 WiFiStatus: WL_IDLE_STATUS 0 ESPeasy internal wifi status: DISCONNECTED
00:01:35.610 : (16368) Info : WiFi : Start network scan all channels
00:01:37.794 : (16136) Info : WiFi : Scan finished, found: 3
00:01:37.797 : (16256) Info : WIFI : Arduino wifi status: WL_IDLE_STATUS 0 ESPeasy internal wifi status: DISCONNECTED
00:01:46.951 : (16288) Info : WD : Uptime 2 ConnectFailures 0 FreeMem 16424 WiFiStatus: WL_IDLE_STATUS 0 ESPeasy internal wifi status: DISCONNECTED
If I try with the help of Thermite:
00:01:16.947 : (16288) Info : WD : Uptime 1 ConnectFailures 0 FreeMem 16424 WiFiStatus: WL_IDLE_STATUS 0 ESPeasy internal wifi status: DISCONNECTED
00:01:35.608 : (16368) Info : WiFi : Start network scan all channels
00:01:37.792 : (16056) Info : WiFi : Scan finished, found: 4
00:01:37.795 : (16256) Info : WIFI : Arduino wifi status: WL_IDLE_STATUS 0 ESPeasy internal wifi status: DISCONNECTED
If I set up the parameters :
wifissid,WIFINAME
wifikey,WIFIPASS
save
I get the OK answer.
But here, also I do not get a wifi connection. Only after a few power off / on, I can setup the wifi with the help of the AP mode.
Every time I load the ESPEASY firmware on an ESP32 or ESP8266, I have this kind of problem.
As I've already said with TASMOTA ESP Web Tools, it works the first time.
This is just for your information.
Otto
wifissid,WIFINAME
wifikey,WIFIPASS
save
Otto
