Good day,
I would like to control my heat pump "Panasonic WH-SXF12D9E8 Heat Pump" with the help of esp easy, but I am new to this. Can someone help?
Panasonic WH-SXF12D9E8 Heat Pump & ESP easy
Re: Panasonic WH-SXF12D9E8 Heat Pump & ESP easy
Assuming this device is controlled using an infrared remote control, you might be able to send commands and possibly receive status updates using the IRremoteESP8266 library or HeatpumpIR library, that is supported by ESPEasy in the IR builds (best use an ESP32 as that includes most/all of the protocols, in ESP8266 some are excluded for size reasons).
You might want to investigate if your brand & model is supported there.
Connecting both an IR transmitter-LED and IR receiver to an ESP should probably get you going.
Good day,
unfortunately, it is not possible to control using IR, there is a controller with a display built into the heat pump unit.
- aquarea2+.jpg (36.98 KiB) Viewed 724 times
- aquarea5.jpg (13.41 KiB) Viewed 724 times
Well, if there's no way of externally controlling the device, I don't know how to 'fix' that using ESPEasy...
