Use_Servo support?
Use_Servo support?
I need a binary version of ESPEASY, that supports use of servos, to apply to a 1MB ESP8266.
How can I identify a recent firmware for this?
(ESP_Easy_mega_20210114_normal_ESP8266_1M, which is currently running on this device yields "4215286618: USE_SERVO not included in build" if I attempt to address a servo. )
Your thoughts & advice?
Thanks,
Brian H.
Thanks,
Brian H.
Re: Use_Servo support?
Best solution would probably be to build a Custom version of ESPEasy, that has the plugins you need, and FEATURE_SERVO 1 (enabled, we renamed the USE_ defines to FEATURE_ with value 0 or 1).
(I really need to update the docs on how to build a Custom ESPEasy using VSCode/PlatformIO, either by modifying the pre_custom_esp....py or Custom.h files)
Will that run under Linux? I am pretty much exclusively Linux based these days.VSCode/PlatformIO
Thx.
Brian H.
Yes, both VSCode and PlatformIO will run on Windows, Linux and Mac. (It's just that I'm a Windows user, but that shouldn't stop you from doing this on Linux )
Most likely VSCode expects you to run a GUI (not just a plain text terminal via ssh), but I expect anyone using Linux on a desktop/laptop computer does that via a Graphical User Interface. (The only Linux I regularly interact with are servers, from cloud-based application-servers with the latest Redhat OS to a RPi running my Domoticz instance )
You can also look at the build script in the tools directory.
Please make sure to read the script first to see if there are any wrong assumptions being made for your platform.
It seems I'll have to add a KEEP_SERVO compile-time flag, like done for RTTTL, to have that enabled, as even for the Custom ESP8266 1M builds the Servo feature is forcefully inhibited
I'll see what I can do about that.
@uxhamby I've added a pull request to allow FEATURE_SERVO to be enabled for Custom builds, but none of the Custom builds has that enabled by default.
Can you list the plugins you actually use, then I'll build a custom ESP8266 1MB firmware with those plugins and Servo enabled, for you to test.
At this time I am only using the Servo on this particular device and triggering it with HTTL and MQTT commands from elsewhere. I do need to make use of the position 9000 command to turn the power off to the Servo, presumably that is part and parcel of the Servo plugin?
Cheers,
Brian H.
Thanks!I'll build a custom ESP8266 1MB firmware with those plugins and Servo enabled, for you to test.
Cheers,
Brian H.
Thanks,
Brian H.
Yes, I would like this too. Where are the existing docs located?(I really need to update the docs on how to build a Custom ESPEasy using VSCode/PlatformIO, either by modifying the pre_custom_esp....py or Custom.h files)
Thanks,
Brian H.
That switching off at 9000 is indeed a feature of the servo command/handling, and as documented here (scroll down a bit to the servo command)uxhamby wrote: ↑05 Feb 2024, 22:51 At this time I am only using the Servo on this particular device and triggering it with HTTL and MQTT commands from elsewhere. I do need to make use of the position 9000 command to turn the power off to the Servo, presumably that is part and parcel of the Servo plugin?
There's a PlatformIO page that describes how to set up the required components (the Python part is aimed at Windows, as that doesn't come standard with Python), You'll need Python 3.11 installed.
The Custom build stuff is documented on that same page, over here: PlatformIO page, the example uses the custom_ESP8266_4M1M environment, but for the 1M devices, you'll need either custom_274_ESP8266_1M (using the default Arduino 2.74 framework) or custom_beta_ESP8266_1M (using an Arduino framework 3.x beta).
Uploading such build, that's to be found in the "<ESPEasy_checkout>/build_output/bin" directory, should be a known procedure for you, I assume
I've created a build, from the PR mentioned above, with a modified: tools/pio/pre_custom_esp82xx.py (included in the .zip):
This improvement has been merged and will be available in the next release of ESPEasy
Here is my servo in operation:
https://youtube.com/shorts/GmPMB6-Er2Q? ... k-uFIbpi0p
This is rework of an old project from before the position 9000 was included. The servos were short lived under the strain. Hopefully the position 9000 power down, will help with servo longevity.
Thanks again,
Brian H.
Thanks again,
Brian H.
I think your light switch also needs some 3D printed cover
Users browsing this forum: No registered users and 41 guests
