Wemos C3 fw upload
Wemos C3 fw upload
Hi all,
I buy Wemos C3 mini V2.1.0, but I am not able flash the FW... I testing all ways, but still not.
Anyone who can write step by step pls...
Thank !
Thank !
Re: Wemos C3 fw upload
Have you tried the web flasher?
https://td-er.nl/ESPEasy/latest/
Sometimes you need to keep the "boot" button pressed. (labeled "9" on the Wemos C3 mini)
Hi, yes i try also... But solved. Poor chinese version :/ I have 3 the same, two not working, 3th work, also work board when i buy in local store...
I try today connect some sensors.
On chinese board nor working :/ other working with DS18B20. But I have some issue with analog input.
I have from battery resistor divider roughly /10 on analog input is +/- 0,42V my formula in device setting is (%value%*18.7/4095). When I apply formula in device, output is ok 4,2 +/-, but after reboot is value 1.53. Open device, no change, make submit and output is ok... Something after reboot is wrong
ADC1 CH0, tested with all att options
TD-er wrote: ↑01 Feb 2024, 23:33 Have you tried the web flasher?
If it is a board with USB-C connector, please try with rotating your USB-C connector 180 degree.
What do you mean about wrong output on ADC after reboot?
ADC is an input pin.
And if it is 'floating' as in nothing connected to it, then it can read any analog value.
Please note that the ESP32-C series do not need to have GPIO-0 pulled to GND, but those need GPIO-9 to be pulled to GND to enter flash mode.
See: https://espeasy.readthedocs.io/en/lates ... pping-pins
I use ADC1 CH0 as baterry monitoring is not ok ?
TD-er wrote: ↑04 Feb 2024, 20:46 What do you mean about wrong output on ADC after reboot?
Should not be a problem as that's the same pin as GPIO-0.
On the ESP32-C3, this is not one of the strapping pins so this pin can have any state during boot.
However it is possible the pin is pulled-up (or down) during boot and this might briefly change the charge of any capacitor you may have placed over the analog input to filter out noise.
So maybe the first reading of the analog input value may be wrong. (or first few readings)
I have GPIO-0 as input for battery measuring over resistive divider. On input is battery voltage/10, for examle 0,4V max.
I setup the "device" set the formula (%value%*18.7/4095) , submit and on device list i see good number 4,2V, everithing is ok, but after reboot i dont see 4,2V but 1,53V.
After open the device, only submit is value again in 4,2v...
I think after reboot is not aplied formula (%value%*18.7/4095)
What interval have you set for the task?
Does it change after executing the command "taskrun,<adc-task>" ? (<adc-task> should be the number or name of the task that has your ADC configuration)
Nothing...
Task nr. 2 or name "analog"
TaskRun,<2> or TaskRun,<analog>
INVALID_PARAMETERS
INVALID_PARAMETERS
Without the <>
taskrun,2
That should have either been "taskrun,2" or "taskrun,analog"... I've used the same example-syntax as used in the documentation
Also try it without <>, but no change when run command.
After open device/edit/submit is ok...
Build: ESP_Easy_mega_20240127_normal_ESP32c3_4M316k_LittleFS_CDC Jan 27 2024
33434: SYS : -81
35264: DS : Temperature: 7.9 (28-41-0c-96-f0-01-3c-c1 [DS18B20])
38384: ADC : Analog value: 328 = 1.50
38432: SYS : -76
40174: DS : Temperature: 7.9 (28-41-0c-96-f0-01-3c-c1 [DS18B20])
43385: ADC : Analog value: 320 = 1.46
43432: SYS : -78
45177: DS : Temperature: 7.9 (28-41-0c-96-f0-01-3c-c1 [DS18B20])
48384: ADC : Analog value: 330 = 1.51
48432: SYS : -78
48542: HTTP: TaskRun,2
48555: ADC : Analog value: 283 = 1.29
48628: static_file: /favicon.ico to: 192.168.100.18
50181: DS : Temperature: 7.9 (28-41-0c-96-f0-01-3c-c1 [DS18B20])
53432: SYS : -86
53554: ADC : Analog value: 328 = 1.50
55186: DS : Temperature: 7.9 (28-41-0c-96-f0-01-3c-c1 [DS18B20])
58432: SYS : -77
58553: ADC : Analog value: 319 = 1.46
60187: DS : Temperature: 7.9 (28-41-0c-96-f0-01-3c-c1 [DS18B20])
63007: HTTP: TaskRun,analog
63021: ADC : Analog value: 328 = 1.50
63141: static_file: /favicon.ico to: 192.168.100.18
63433: SYS : -80
65190: DS : Temperature: 7.9 (28-41-0c-96-f0-01-3c-c1 [DS18B20])
68018: ADC : Analog value: 319 = 1.46
68467: SYS : -77
70191: DS : Temperature: 7.8 (28-41-0c-96-f0-01-3c-c1 [DS18B20])
70996: static_file: /favicon.ico to: 192.168.100.18
73079: static_file: /favicon.ico to: 192.168.100.18
73100: ADC : Analog value: 328 = 1.50
73433: SYS : -77
75242: DS : Temperature: 7.9 (28-41-0c-96-f0-01-3c-c1 [DS18B20])
75332: SaveToFile: CustomTaskSettings index: 1
75334: SaveToFile: free stack: 6296
77269: FILE : Saved config.dat offset: 35840 size: 7
77271: SaveToFile: free stack after: 6296
77279: SaveToFile: TaskSettings index: 1
77281: SaveToFile: free stack: 6904
79246: FILE : Saved config.dat offset: 34816 size: 536
79248: SaveToFile: free stack after: 6904
79279: ESPEasy console using ESPEasySerial
79301: ESPEasy console fallback enabled
79303: Skip saving settings, not changed
79304: Skip saving SecuritySettings, not changed
79324: mDNS : Starting mDNS...
79330: mDNS : Started, with name: Pepa-teplomer-sever-11.local
79363: ADC : Analog value: 863 = 3.94
79572: static_file: /favicon.ico to: 192.168.100.18
79597: SYS : -79
79622: ADC : Analog value: 872 = 3.98
80433: DS : Temperature: 7.9 (28-41-0c-96-f0-01-3c-c1 [DS18B20])
33434: SYS : -81
38432: SYS : -76
43432: SYS : -78
48432: SYS : -78
53432: SYS : -86
58432: SYS : -77
63433: SYS : -80
68467: SYS : -77
73433: SYS : -77
79597: SYS : -79
Users browsing this forum: No registered users and 46 guests
