Is there a special command to reset the P077-pulses?
Or is a task disable/enable the only way?
Reset pulses in P077
Re: Reset pulses in P077
Right now I don't see how it can be cleared otherwise.
Anyway you don't need to call save inbetween.
But you will loose any stats when enable/disable the task, so I can imagine the use of such a command
Thank you...
Users browsing this forum: Jieffe and 34 guests
