Nextion display plugin
- ledfreak3d
Re: Nextion display plugin
I think I might have one or 2 laying around let me check tonight
both the esp07 and 12 and 12e fit on there I think I have both of them
think I have one or 2 ones that have not been populated yet
Domoticz Synology Esp easy Location Netherlands /Hoorn
If you have any extra pcb's you like to sell, please let me know. Iam working on building a Nextion/RFID alarm panel based on ESP8266 and Domoticz.
I prefer the populated boards, but bare prints would also do.
With kind regards,
Remco
With kind regards,
Remco
- ledfreak3d
Hey Remco.
I will check tonight im sure I have some unpopulated and some populated ones
are you based in the Netherlands ?
Yep,
Based in Netherlands, Overijssel
- ledfreak3d
thought so
if anybody is interested can put in a new order of boards
ill check tonight how many I still have
still have enough components to make more boards but don't have any esp12e's or buttons at the moment .
still thinking about making a custome domoticz sensor board
eather with esp8266 or a atmel / nrf combo for my sensors
I'd be keen on a couple of populated or partly populated boards but I live in NZ.ledfreak3d wrote:thought so
Numerous Sonoff's and Shelly's, Home Assistant on Intel NUC i3, Aeotec Z-Stick (Gen 5), deCONZ Zigbee Stick, 3 x Echo Dot's and 5 x Google Home
- ledfreak3d
need to get me a decent hot air station to do smd properly
now doing it with a normal soldering iron its doable but its not prety
- ledfreak3d
Double checked.
I have 4 unpopulated boards and
2 populated with a esp07 on it
Would you post one of the populated boards to NZ to allow me to test? I can pay with PayPal or Amazon UK gift card. Understand if it's too much hassle.ledfreak3d wrote:Double checked.
I like to have one populated and one unpopulated board if possible.
Gr. Remco
Gr. Remco
What is the advantage of this Board over a wemos d1?
- ledfreak3d
should be no problemxbmcnut wrote:Would you post one of the populated boards to NZ to allow me to test? I can pay with PayPal or Amazon UK gift card. Understand if it's too much hassle.ledfreak3d wrote:Double checked.
please contact me on email if anybody is interested in a board
ledfreak3d@gmail.com
Any new developments here?
- ledfreak3d
What direction are you heading to?
HelloBertB wrote:I also created a screen for the display itself.
Friend can help?
I bought a 2.4 display and I can not seem to get it working
Compiled the plugin without problems in esp, but it does not give
Do I need to put any software on the display?
Yes, you have to download the ide from Nextion. In there you need to create objects like a textbox, where you can send data to. There are tutorials on the internet. Just search for Nextion and arduino.
BertB wrote:Yes, you have to download the ide from Nextion. In there you need to create objects like a textbox, where you can send data to. There are tutorials on the internet. Just search for Nextion and arduino.
thank you so much
I already got it, it's working very well.
It is possible through the touch a button in the nextion to send a command to the domoticz?
To then at least enable and disable a gpio on the esp8266 board?
I am using the previously mentioned Nextion Plugin (104) and came across a problem.
I cannot output to a n? number if it's below 100, unless I put zero's in front to
make a 3 digit number. Like 001, 073 etc.
Any idea what I am doing wrong ?
Nick
PS, I am using an ESP8266 NodeMCU V0.9. This maybe the problem, I will try on a 1.0 later on and report back
Nick
ESP32, Arduino's,Raspberry Pi's, ESP8266's, Nextion's, Sonoff's, LightWaveRF's, RFXCom 433, and a headache
And a HackRF One, as a present to myself.
Well,
Just tried it with ESPEasy 147 on a nodemcu v 1.0 and it does the same.
Can't understand this a tall
I am compiling without problemsnick-head wrote:Well,
You have to inside the ESPEasy file _104.ino
I have the same problem. Need to dig into this.nick-head wrote:Hi,
Nick
Anyone found out why this is happening ?
Yes. I tried to put the entire file in the ESP8266nu/ESPEasyPluginPlayground. Hope I took the right steps.nick-head wrote:Anyone found out why this is happening ?
In the mean time, hereunder the new code.
#include <Arduino.h>
#include <SoftwareSerial.h>
//#################################### Plugin 117: Nextion <info@sensorio.cz> ###########################
#define PLUGIN_117
#define PLUGIN_ID_117 117
#define PLUGIN_NAME_117 "Display: Nextion"
#define PLUGIN_VALUENAME1_117 "code"
unsigned long Plugin_117_code = 0;
int8_t Plugin_117_RXpin = -1;
int8_t Plugin_117_TXpin = -1;
SoftwareSerial *nextion;
boolean Plugin_117(byte function, struct EventStruct *event, String &string) {
boolean success = false;
static byte displayTimer = 0;
switch (function) {
case PLUGIN_DEVICE_ADD: {
Device[++deviceCount].Number = PLUGIN_ID_117;
Device[deviceCount].Type = DEVICE_TYPE_DUAL;
Device[deviceCount].VType = SENSOR_TYPE_QUAD;
Device[deviceCount].PullUpOption = true;
Device[deviceCount].ValueCount = 4;
case PLUGIN_GET_DEVICENAME: {
string = F(PLUGIN_NAME_117);
case PLUGIN_GET_DEVICEVALUENAMES: {
strcpy_P(ExtraTaskSettings.TaskDeviceValueNames[0],PSTR(PLUGIN_VALUENAME1_117));
case PLUGIN_TEN_PER_SECOND: {
char __buffer[80];
uint16_t i;
uint8_t c;
while (nextion->available() > 0) {
delay(10);
c = nextion->read();
if (0x65 == c) {
if (nextion->available() >= 6) {
__buffer[0] = c;
for (i = 1; i < 7; i++) {
__buffer[i] = nextion->read();
__buffer[i] = 0x00;
if (0xFF == __buffer[4] && 0xFF == __buffer[5] && 0xFF == __buffer[6]) {
Plugin_117_code = ((__buffer[1] >> 8) & __buffer[2] >> 8) & __buffer[3];
UserVar[event->BaseVarIndex] = __buffer[1] * 256 + __buffer[2];
UserVar[event->BaseVarIndex + 1] = __buffer[3];
String log = F("Nextion : code: ");
log += __buffer[1];
log += ",";
log += __buffer[2];
log += ",";
log += __buffer[3];
addLog(LOG_LEVEL_INFO, log);
sendData(event);
} else {
if (c == 's') {
i = 1;
__buffer[0] = c;
c=0;
__buffer[i++] = nextion->read();
Serial.write((char)__buffer[i]);
Serial.println();
__buffer[i] = 0x00;
UserVar[event->BaseVarIndex] = __buffer[2];
UserVar[event->BaseVarIndex+1] = __buffer[3];
UserVar[event->BaseVarIndex+2] = __buffer[4];
UserVar[event->BaseVarIndex+3] = __buffer[5];
String log = F("Nextion : send command: ");
log += __buffer;
log += UserVar[event->BaseVarIndex];
ExecuteCommand(VALUE_SOURCE_SYSTEM, __buffer);
if (Settings.TaskDevicePin3[event->TaskIndex] != -1) {
if (!digitalRead(Settings.TaskDevicePin3[event->TaskIndex])) {
Plugin_117_displayOn();
displayTimer = Settings.TaskDevicePluginConfig[event->TaskIndex][2];
success = true;
case PLUGIN_ONCE_A_SECOND: {
if ( displayTimer > 0) {
displayTimer--;
if (displayTimer == 0)
Plugin_117_displayOff();
case PLUGIN_WEBFORM_SAVE: {
String plugin1 = WebServer.arg("plugin_117_timer");
Settings.TaskDevicePluginConfig[event->TaskIndex][0] = plugin1.toInt();
String plugin2 = WebServer.arg("plugin_117_rxwait");
Settings.TaskDevicePluginConfig[event->TaskIndex][1] = plugin2.toInt();
String plugin3 = WebServer.arg("plugin_117_events");
Settings.TaskDevicePluginConfig[event->TaskIndex][2] = plugin3.toInt();
String plugin4 = WebServer.arg("plugin_117_sensortype");
Settings.TaskDevicePluginConfig[event->TaskIndex][3] = plugin4.toInt();
char deviceTemplate[8][64];
for (byte varNr = 0; varNr < 8; varNr++) {
char argc[25];
String arg = F("Plugin_117_template");
arg += varNr + 1;
arg.toCharArray(argc, 25);
String tmpString = WebServer.arg(argc);
strncpy(deviceTemplate[varNr], tmpString.c_str(), sizeof(deviceTemplate[varNr]));
// Settings.TaskDeviceID[event->TaskIndex] = 1; // temp fix, needs a dummy value
success = true;
case PLUGIN_WEBFORM_LOAD: {
char tmpString[128];
LoadCustomTaskSettings(event->TaskIndex, (byte*)&deviceTemplate, sizeof(deviceTemplate));
string += F("<TR><TD>Line ");
string += varNr + 1;
string += F(":<TD><input type='text'li size='50' maxlength='50' name='Plugin_117_template");
string += F("' value='");
string += deviceTemplate[varNr];
string += F("'>");
string += F("<TR><TD>Display button:<TD>");
addPinSelect(false, string, "taskdevicepin3", Settings.TaskDevicePin3[event->TaskIndex]);
sprintf_P(tmpString, PSTR("<TR><TD>Display Timeout:<TD><input type='text' name='plugin_117_timer' value='%u'>"), Settings.TaskDevicePluginConfig[event->TaskIndex][2]);
string += tmpString;
success = true;
case PLUGIN_INIT: {
LoadTaskSettings(event->TaskIndex);
// if ((ExtraTaskSettings.TaskDevicePluginConfigLong[0] != 0) && (ExtraTaskSettings.TaskDevicePluginConfigLong[1] != 0)) {
// if (Settings.TaskDevicePin1[event->TaskIndex] != -1) {
// pinMode(Settings.TaskDevicePin1[event->TaskIndex], OUTPUT);
// digitalWrite(Settings.TaskDevicePin1[event->TaskIndex], LOW);
// delay(500);
// digitalWrite(Settings.TaskDevicePin1[event->TaskIndex], HIGH);
// pinMode(Settings.TaskDevicePin1[event->TaskIndex], INPUT_PULLUP);
pinMode(Settings.TaskDevicePin3[event->TaskIndex], INPUT_PULLUP);
Plugin_117_RXpin = Settings.TaskDevicePin1[event->TaskIndex];
// pinMode(Plugin_117_RXpin, INPUT_PULLUP);
// attachInterrupt(Plugin_117_RXpin, RF_ISR, CHANGE);
success = true;
if (Settings.TaskDevicePin2[event->TaskIndex] != -1)
Plugin_117_TXpin = Settings.TaskDevicePin2[event->TaskIndex];
// pinMode(Plugin_117_TXpin, OUTPUT);
if (!nextion) {
// nextion = new SoftwareSerial(13,14);
nextion = new SoftwareSerial(Plugin_117_RXpin , Plugin_117_TXpin);
Serial.print("pin: ");
Serial.println(Settings.TaskDevicePin1[event->TaskIndex]);
nextion->begin(9600);
success = true;
case PLUGIN_READ: {
for (byte x = 0; x < 8; x++) {
String tmpString = deviceTemplate[x];
if (tmpString.length()) {
String newString = parseTemplate(tmpString, 0);
Serial.println(newString);
sendCommand(newString.c_str());
success = false;
case PLUGIN_WRITE: {
String tmpString = string;
if (argIndex)
tmpString = tmpString.substring(0, argIndex);
if (tmpString.equalsIgnoreCase(F("NEXTION"))) {
argIndex = string.indexOf(',');
tmpString = string.substring(argIndex + 1);
sendCommand(tmpString.c_str());
Serial.println(tmpString);
success = true;
return success;
void Plugin_117_displayOn() {
void Plugin_117_displayOff() {
void sendCommand(const char *cmd) {
nextion->print(cmd);
nextion->write(0xff);
Nice one Bert,
I am just in the process of uploading to the ESP.
Right, uploaded. Had to remove original plugin as it has redefinitions of SoftwarSerial and other things.
OK, done.
Can't find RX/TX as before. Can't even make it produce anything on the screen.
Totally different interface. Will have to look later, I may have done something wrong at my end.
OK, done.
I found that the originale interface did not work anymore, so I had to change it.nick-head wrote:Nice one Bert,
OK, done.
1st GPIO is now Rx and 2nd GPIO Tx.
Sorry for the inconvenience, but please do not forget, I am only trying to persuade more professional programmers to make ik more beautiful
IDX/Var is not yet functional and neither are Display button and Display Timeout.
You can send commands and data to it:
http://espeasy-ip/control?cmd=NEXTION,rest ====> resets the display
http://espeasy-ip/control?cmd=NEXTION,dim=50 ====> dims the backlight to 50%
http://espeasy-ip/control?cmd=NEXTION,page0.n0.val=12 ====> sets the value of n0 on page 0 to 12
http://espeasy-ip/control?cmd=NEXTION,page0.t5.txt="hoi" ====> sets the text of t0 on page 0 to hoi
- P104_IF.png (58.8 KiB) Viewed 184757 times
No problem Bert,
I have only been experimenting with the plugins for a few days and I have learnt a few things.
I have great respect for any developers who commit their time to produce "free" software based
on ideas generated by many people.
I am using ESPeasy in my home automation system and I have a lot to learn.
Thanks for your time and help.
Nick
Nick
That has cured the <100 problem Bert, works absolutely fine now.
now I have to find something to do with it now.
Thanks Bert, your a star.
Nick
Nick
Glad tot be of help,nick-head wrote:That has cured the <100 problem Bert, works absolutely fine now.
Nick
Congratulations for this development. I bought a direct nextion when i discovered it.
I try this plugin for a few days and I can not.
I created a page, a text box, a value box and a gauge.
I have compiled the last plugin on this page 8 and others before.
I plugged the RX on GPIO13- D7 and TX on GPIO14-D5
It does not communicate, I try the lines or the rules.
Ex line 1: page0.n0.val = 20
Line 2 : page0.t0.txt="[ds18b20#TEMPERATURE]"
Rules :
On ds18b20#TEMPERATURE do
NEXTION,t0.txt="[ds18b20#TEMPERATURE]"
What I forgot ? Thanks
Rules :
Hi, sorry to hear it does not work for you.
I assume you can see the setup page in devices in ESPEasy?
And that you can set GPIO 1 and GPIO 2
And that you did not mix up Tx and Rx?
What hardware do you use?
Thx for your help.
I use a wemos d1 mini.
I paste the sketch in espeay.ino with plugin p117... I compile, it's good. I upload.
Yes i can see the configuration page with the gpio.
I configure the gpio for the rx and tx, not error.
I made a page on the nextion with try a block t0, n0, z0...
I write on in the line 1, line 2....and with rules to try...
What is the wiring ? Need a special library, i have nextion library and i didn't error when i compile, special serial 9600 ou?
Configuration espeasy : domoticz mqtt, spi, configuration pin ?
I do not use the Nextion library.
The Nextion itself is a basic model.
The Nextion requires 5 volt power and the ESP 8266 can only handle up to 3.3 volt.
On the Tx pin of the Wemos, you can connect the Rx of the Nextion.
On the Rx pin you need a voltage limiter, because the voltage of the Nextion Tx pin is 5 volts.
For that purpose I use a small signal, high speed diode and a resistor. 1n4448 or so will do fine.
Kathode to Tx of Nextion.
Anode to Rx of Wemos
Resistor of some 10 k or so from Rx of Wemos to + 3.3 volt of Wemos.
You can also try an use the Nextion IDE with a USB to serial converterd to test the Nextion.
Hi Bert,
I think I'm having a similar (or the same) problem as Jeff.
I tried your plugin with a plain esp-12f or a nodemcu-V2.
The pins I use are GPIO13 und 14 (D7 and D5).
The pins itself are functional: for a test I changed the device to a switch and shortened them to ground. success.
Then I connected an FTDI to the pins and there is nothing. It doesn't matter if I use the URL with control?cmd=NEXTION,dim=0 or something in the device configuration. The control window always stays empty. It seems the plugin does not use the configured pins.
The hardware must be ok. For the next test I uploaded the firmware esplink, and then I saw communication on the wire.
Do you have another idea what I can check?
regards
Pete
regards
Pete
I will start with a fresh wemos to test.
You could also try to change a part of the code and re compile:
Change:
if (!nextion) {
into:
if (!nextion) {
// nextion = new SoftwareSerial(Plugin_117_RXpin , Plugin_117_TXpin);
Per haps something goes wrong with the pin assignment.
SPI has to be disabled.
Change:
if (!nextion) {
into:
if (!nextion) {
Hi Bert,
it works now. Thanks for your quick workaround.
regards
regards
Thank you for the time.
I understand a little better but I still have questions.
The tx and the rx of the nextion, is it connected to the tx and the rx of the wemos or the GPIO 13 and 14 of the wemos ?
The 5v on the 3.3v, I had not seen my mistake
D3 : 1n4007
R2 : 10K
I have ordered a level swicher since, 60 days have not arrived!
I recompiled, tried my editing on 13 and 14 with your proposition but nothing, I tried other GPIOs, nothing either.
My program nextion is it good ? I draw a txt (t0), a number (N0) and a jauge (Z0) !
I go to ski tomorrow, we will see my return
D3 : 1n4007
R2 : 10K
It workThe pins itself are functional: for a test I changed the device to a switch and shortened them to ground. success.
It workYou can also try an use the Nextion IDE with a USB to serial converterd to test the Nextion.
For only sending data from the Wemos to the Nextion, Rx on the Wemos (Blue wire) is not required.
This is how I connect my nextion.
You can choose to feed it from a strong (Nextion requires sufficient power) usb or an external 5 volt DC power supply.
I tested it with a 1n4448 and a 1n4004 diode.
the colors are the colors of the Nextion cable, where:
blue = Tx (Nextion)
yellow = Rx (Nextion)
red = + 5v
black = gnd
It can be necessary to add capacitors.
blue = Tx (Nextion)
red = + 5v
black = gnd
Hi everyone.
So glad this has been developed. I am going to replace my previous incarnation of Heating Thermostat (using a sonoff TH) with this Nextion. I have used Scargills PCB and screen design (modified) with a relay board and small PSU from a phone charger.
The advantage of Scargills board is that is has all the breakouts purposely positioned and also screws to the back of the Nextion screen making it compact.
I added the MQTT Import utility so I can pick up my Heating setpoint and display it along side the Temperature and Humidity from the DHT22 mounted at the bottom. I also brought up the Relay status (light on the right)
Thank you for help me.BertB wrote:For only sending data from the Wemos to the Nextion, Rx on the Wemos (Blue wire) is not required.
blue = Tx (Nextion)
red = + 5v
black = gnd
My wiring was not good for Tx. I use an external 5 volt power.
I'll try to my come back.
If some would like to share their hmi project, it would be great.
Yes it work
Thanks @BertB
Thanks @BertB
I know how to handle texts and retrieve values via mqtt
How do you do the buttons to send a command to domoticz ?
I am trying to get the input from buttons as follows:
For example, in the Nextion, I have put the following lines in the Tough Release Event section of a button:
if(va1.val==0)
va1.val=1
print "|s"
print "idx=99&switchcmd=On"
printh 0a
}else
va1.val=0
print "|s"
print "idx=99&switchcmd=Off"
printh 0x0a
I use variable va1 as a toggle state memory.
Anyway, the idea is that the Nextion sends idx=99&switchcmd=On en idx=99&switchcmd=Off.
Those values I can now project in the variables of the Nextion plugin. Now I am trying to send those values to Domoticz.
Since I am a self tought programmer, this is not a fast creation process.
Herunder is the accompaniing plugin code. I still do not get it in the playground.
if(va1.val==0)
va1.val=1
print "|s"
printh 0a
}else
va1.val=0
print "|s"
printh 0x0a
#define PLUGIN_117
switch (function) {
char __buffer[80];
uint16_t i;
uint8_t c;
String Vidx;
String Nvalue;
String Svalue;
String Nswitch;
delay(10);
if (0x65 == c) {
__buffer[0] = c;
__buffer[i] = 0x00;
log += __buffer[1];
log += ",";
log += __buffer[2];
log += ",";
log += __buffer[3];
sendData(event);
} else {
if (c == '|') {
i = 1;
__buffer[0] = c;
c=0;
if (__buffer[i]==0x0d) break;
i++;
Serial.println("end");
__buffer[i] = 0x00;
String tmpString = __buffer;
int argIndex = tmpString.indexOf("idx=");
int argEnd = tmpString.indexOf('&');
if (argIndex)
Vidx = tmpString.substring(argIndex + 4,argEnd);
switch (__buffer[1]){
case 'u':
argIndex = tmpString.indexOf("nvalue=");
argEnd = tmpString.indexOf('&',argIndex);
if (argIndex)
Nvalue = tmpString.substring(argIndex + 7,argEnd);
argIndex = tmpString.indexOf("svalue=",argIndex);
argEnd = tmpString.indexOf(0x0a);
if (argIndex)
Svalue = tmpString.substring(argIndex + 7,argEnd);
case 's':
argIndex = tmpString.indexOf("switchcmd=",argIndex);
if (argIndex)
Nvalue = tmpString.substring(argIndex + 10,argEnd);
if (Nvalue=="On")
Nswitch='1';
if (Nvalue=="Off")
Nswitch='0';
// tmpString = tmpString.substring(0, argIndex);
// if (tmpString.equalsIgnoreCase(F("NEXTION"))) {
// argIndex = string.indexOf(',');
// tmpString = string.substring(argIndex + 1);
// sendCommand(tmpString.c_str());
// success = true;
Serial.println(Vidx);
Serial.println(Nvalue);
Serial.println(Svalue);
Serial.println(Nswitch);
UserVar[event->BaseVarIndex] = Vidx.toFloat();
UserVar[event->BaseVarIndex+1] = Nvalue.toFloat();
UserVar[event->BaseVarIndex+2] = Svalue.toFloat();
UserVar[event->BaseVarIndex+3] = Nswitch.toFloat();
log += __buffer;
success = true;
displayTimer--;
char argc[25];
arg += varNr + 1;
success = true;
string += F("'>");
success = true;
case PLUGIN_INIT: {
// delay(500);
success = true;
if (!nextion) {
Serial.println(Settings.TaskDevicePin2[event->TaskIndex]);
Serial.println(Plugin_117_RXpin);
Serial.println(Plugin_117_TXpin);
success = true;
case PLUGIN_READ: {
success = false;
if (argIndex)
success = true;
return success;
With the advice of @majklovec page 4 I managed to understand how to send commands to domoticz.
It's simple.
In a rule
log :
Domoticz log :
I'm happy
It's simple.
I create a button, when i push in the logs1) Try to make a button in the Nextion and check on "Touch release event" - "Send component id"
See the event sent
2726562 : Nextion : code:
2726563 : EVENT: NEXTION#code=6.00
2726566 : EVENT: NEXTION#=0.00
2726569 : EVENT: NEXTION#=0.00
2726571 : EVENT: NEXTION#=0.00
on NEXTION#code=6.00 do
sendtohttp 192.168.1.19,8080,/json.htm?param=switchlight&type=command&idx=52&switchcmd=On
2765418 : EVENT: NEXTION#code=6.00
2765421 : ACT : sendtohttp 192.168.1.19,8080,/json.htm?param=switchlight&type=command&idx=52&switchcmd=On
2765479 : EVENT: NEXTION#=0.00
2765482 : EVENT: NEXTION#=0.00
2765484 : EVENT: NEXTION#=0.00
2017-01-16 23:13:14.416 User: Admin initiated a switch command (52/Led buanderie/On)
Ah ... I am going to try that tonight
This works very well too.
It is my First Time here. I use one Wemos with a 2,8" Nextion. I have found this Forum to handle it with espeasy.
I have install r147 rc08 yesterday. Everything ok by flash. Now when i Look in to the devices i dosn't finde Nextion display. What is wrong?
The second thing i'll not understand.... the Arduino code that is post here in these thread have i to install at the Wemos too??
I will use ESP and Nextion with Fhem.
Thanks for helping
Marko
Thanks for helping
Marko
Hi Marko,
Yes, you have to copy the code in this thread into a file named _P117_Nextion.ino.
I use wordpad for that.
Save that file in the ESPEasy folder.
Start the Arduino IDE, complie and flash.
That should be it.
That should be it.
