How to use the MCP23017
asm7100
#1 Post by asm7100 » 18 Sep 2015, 21:25
How do i use the MCP23017 to output from Domoticz??
I like the MCP23017 Port B0 to on/off a led, by activate a switch on Domoticz
This is my setup i easyesp
Task Settings Value
Device: MCP23017 input
Port: 9
IDX / Var: 5 <- From the Domoticz.
Formula Switch:
What is Formula Switch: to be used to??????
Please Help me.
5xESP-01 - 3xESP-12 - 2xESP-12E 3xRPIb+ - 1xBPIm1 - 3xACTi DOME - 7xACTi Indoor cam. Lot off cisco equ.
Martinus
Re: How to use the MCP23017
#2 Post by Martinus » 19 Sep 2015, 16:35
Output hasn't had much focus yet and currently only direct GPIO and PWM is working through the /control=xxx http interface. The MCP23017 Input device in the dropdownlist is only used to read inputs on the MCP device. For direct output using http you do not need a task setting.
Output should be controlled with something like this to toggle output:
http://<ip>/control?cmd=mcpgpio,9,1
But we need to fix this in the next release.
If you haven't set a password on this ESP, you should be able to use the debug command that still exists in the code:
http://<ip>/?cmd=extwiredout,9,1
http://<ip>/?cmd=extwiredout,9,0
But beware that this will likely be changed.
asm7100
#3 Post by asm7100 » 20 Sep 2015, 12:36
Nice and thanks for the quick answer.
Keep up the good work :-)
By the way if you put one more MCP23017 on it but with another add, will you then get more in/outs??
Martinus
#4 Post by Martinus » 20 Sep 2015, 12:48
asm7100 wrote:By the way if you put one more MCP23017 on it but with another add, will you then get more in/outs??
That's possible. The portnumbers just count up.
The first MCP at address offset 0 uses ports 1-16
The next at addres offset 1 uses ports 17-32
etc
asm7100
#5 Post by asm7100 » 20 Sep 2015, 23:10
Nice.
How about updating the wiki with it. :-)
asm7100
#6 Post by asm7100 » 23 Sep 2015, 14:12
When you use the MCP23017 as inputs, is the internel pullup enabled?
hamster
#7 Post by hamster » 27 Sep 2015, 21:35
First of all.. just like to say this is a fantastic project.. well impressed..!!
Currently using R20..
Following the previous comments, I managed to get the outputs working.. :D
Also wanted to get some inputs working..
I have one input configured but when I tie the contact on the mcp23017 high or low I don't see any immediate change on my domoticz idx. however i do see an update in the history every one minute ??
Any ideas??
asm7100
#8 Post by asm7100 » 27 Sep 2015, 22:33
Yes there is some thing rung there, it's the same is you use GPIO :-(
I try to use it to see if a door is open or closed. (Gpio? to gnd) with or without a pull up res.
hamster
#9 Post by hamster » 28 Sep 2015, 11:38
Thanks Alan
Standard GPIO's are working ok as inputs..
but not on MCP23017.. :(
asm7100
#10 Post by asm7100 » 28 Sep 2015, 12:12
Hamster, do you use pullup res?
hamster
#11 Post by hamster » 28 Sep 2015, 16:36
I tried using a 4k resister but didn't make any difference..
Martinus
#12 Post by Martinus » 28 Sep 2015, 19:09
Sorry to say that the MCP23017 input plugin only works as a periodic input port scan, similar to sensing temperatures.
So it will not act the same as the input switch plugin on local GPIO ports.
asm7100
#13 Post by asm7100 » 28 Sep 2015, 20:08
:-( Can that be changes?
Can we use them as Input and Output, 1 as input, 2, 3 and 4 as output and 8 as input ex.
hamster
#14 Post by hamster » 30 Sep 2015, 20:32
outputs are working with :-
(as posted by martinus)
asm7100
#15 Post by asm7100 » 30 Sep 2015, 21:05
Yes i know, but can it bee uses as a mix, input and outputs.
Martinus
#16 Post by Martinus » 02 Oct 2015, 12:49
asm7100 wrote::-( Can that be changed?
It is changed in R27.
asm7100 wrote:Can we use them as Input and Output, 1 as input, 2, 3 and 4 as output and 8 as input ex.
You can mix input and output for each individual port on the MCP23017.
To use a port as input, select the device and configure that port.
To use a port as output, send the http/mqtt command for that port and it will automatically switch to output.
Martinus
#17 Post by Martinus » 02 Oct 2015, 12:50
asm7100 wrote:When you use the MCP23017 as inputs, is the internel pullup enabled?
Pull-ups on input ports are now enabled by default in R27. So no more floating inputs.
asm7100
#18 Post by asm7100 » 03 Oct 2015, 01:00
Nice thanks for the good work :-)
