MQTT and Thingspeak at the same time
I would like to have both MQTT and Thingspeak support at the same time. Is it possible to make it via the rule engine?
//Peter
//Peter
Re: MQTT and Thingspeak at the same time
Like the idea
- nonflammable
i think it is possible temporarily with two esp8266 configured separately (first with MQTT, second with Thingspeak) and enabled synchronization between them
or use SendToHTTP in rules eg.
SendToHTTP 184.106.153.149,80,/update.html?key=YOURKEY&field1=[your#value]
I don't see why you can not use Rules to send MQTT and the Thingspeak template. I used Domoticz HTTP template and MQTT via rules. I found it was not that reliable in an older version, R104 or R107 I think. The rules would sometimes send the first of the BME280 values and the other 2 would be "null". It worked perfect for a while then it stopped, no idea why. The new versions may work better, there is a newer version of PUBSUB.
My fix was to just switch to openHab MQTT and stopped using rules for sending MQTT. I don't use Thinkgspeak so I can't help there.
I cant get this to worknonflammable wrote: or use SendToHTTP in rules eg.
SendToHTTP 184.106.153.149,80,/update.html?key=mykey&field1=[garaget#Humidity]
Nothing gets updated on Thingspeak, any suggestion?
i got this in the log
128939493 : EVENT: garaget#Humidity=68.00
- nonflammable
http://www.esp8266.nu/index.php/Tutorial_Rulessonnyboy wrote: I cant get this to work
On garaget#Humidity do
- nonflammable
I cant get this to work. My friend petrho will test this this weekend.nonflammable wrote:Solved ?
Got no error in the log, but thingspeak doesent update.
works fine here...
But why cant I send multiple commands?
On System#Uptime do
SendToHTTP 184.106.153.149,80,/update.html?key=xxx&field1=[Temp_Hum#Temperature]
SendToHTTP 184.106.153.149,80,/update.html?key=xxx&field2=[Temp_Hum#Humidity]
SendToHTTP 184.106.153.149,80,/update.html?key=xxx&field3=[System#Uptime]
only sent the first line...
On System#Uptime do
- nonflammable
try to add empty line after "endon" and space before SendToHTTPpetrho wrote:But why cant I send multiple commands?
On Clock#Time do
Unfortunately same problem...nonflammable wrote:try to add empty line after "endon" and space before SendToHTTPpetrho wrote:But why cant I send multiple commands?
On Clock#Time do SendToHTTP 184.106.153.149,80,/update.html?key=xxx&field1=[Temp_Hum#Temperature] SendToHTTP 184.106.153.149,80,/update.html?key=xxx&field2=[Temp_Hum#Humidity] SendToHTTP 184.106.153.149,80,/update.html?key=xxx&field3=[System#Uptime] endon
- nonflammable
this should be ok (Currently, a single channel can only be updated once every 15 seconds.)petrho wrote: Unfortunately same problem...
On Clock#Time do
SendToHTTP 184.106.153.149,80,/update.html?key=xxx&field1=[Temp_Hum#Temperature]&field2=[Temp_Hum#Humidity]&field3=[System#Uptime]
aha - you are right. Is it any delay command possible in the rule engine?nonflammable wrote:this should be ok (Currently, a single channel can only be updated once every 15 seconds.)petrho wrote: Unfortunately same problem...
On Clock#Time do SendToHTTP 184.106.153.149,80,/update.html?key=xxx&field1=[Temp_Hum#Temperature]&field2=[Temp_Hum#Humidity]&field3=[System#Uptime] endon
- nonflammable
Yespetrho wrote: aha - you are right. Is it any delay command possible in the rule engine?
Delay <milliseconds>
On Clock#Time do
Delay 15000
http://www.esp8266.nu/index.php/ESPEasy ... _Reference
