Hi There,
I made a mistake with my wifi settings and now I am unable to connect to the ESP to fix it.
When I look at the terminal output, it connects and disconnects. I thougt an easy fix would be to re flash the firmware, but that does not work as somehow it has stored the old configuration and is not clearing it. Please help
Firmware reload
Re: Firmware reload
have you checked if its gone into AP mode?
See if you can see the ESP_01 wifi station
connect using key 'configesp' then go to 192.168.4.1
Re: Firmware reload
when in terminal , you could type
- settings - to check your settings
- wifissid "your wifiname"
- wifikey "your wifipassword"
- save
- save
