Reboot Loop
Reboot Loop
Dear all,
I did something wrong with my ESP Node MCU....
I did try to upgrde the firmware from 78 to108 with the webinterface.
This option was looking ok.
Only now is the esp in a reboot loop....
Is there a way to reset or factory-settings or clean the flash, or?
Re: Reboot Loop
Sounds similar what i had. Try to flash R108 directly with a serial connection. That works for me.Dylantje wrote:Dear all,
Re: Reboot Loop
ManS-H wrote:Sounds similar what i had. Try to flash R108 directly with a serial connection. That works for me.Dylantje wrote:Dear all,
Do you have a little how to??
Or a link
Re: Reboot Loop
Connect your device with a usb port and use the program inside ESPEasy_R108 Fill the Comport, Flashsize en Build, that's allDylantje wrote:ManS-H wrote:Sounds similar what i had. Try to flash R108 directly with a serial connection. That works for me.Dylantje wrote:Dear all,
Or a link
Re: Reboot Loop
Yep that is what i do...ManS-H wrote:Connect your device with a usb port and use the program inside ESPEasy_R108Dylantje wrote:ManS-H wrote:
Or a link
Writing flash i see, and done @ the end...
Try this with the 78 & 108 version
Only the loop is every time there...
Re: Reboot Loop
Try: http://esp8266.ru/esplorer/ and show us what you see.Dylantje wrote:ManS-H wrote:Dylantje wrote:
Re: Reboot Loop
nice stuff:
Only no change
A reset i did try from esplorer...Only no change
Re: Reboot Loop
Try the ESPEasy commands.Dylantje wrote:nice stuff:
Only no change
- Capture.JPG (134.79 KiB) Viewed 16481 times
Re: Reboot Loop
sorry..
I do not now any commands...
I try Reset and others:
http://www.esp8266.nu/index.php/ESPEasy ... _Reference
No thing change
No thing change
Re: Reboot Loop
P0rt is: 115200 and not 9600Dylantje wrote:sorry..
No thing change
When you type "settings", "reset" or "reboot" you must see something,
Re: Reboot Loop
Did everything again...
Is there no way to reset the flash?
Try to upload the new firmware:
No changesIs there no way to reset the flash?
Re: Reboot Loop
flash-erase multiple times in this forum (widespread )
here: http://www.esp8266.nu/forum/viewtopic.p ... 1732#p8014
and here: http://www.esp8266.nu/forum/viewtopic.p ... lash#p8055
like:
like:
C:\Python27>esptool.py -p COM4 -b 115200 erase_flash
Connecting...
Re: Reboot Loop
Dylan,
It's settings, or reset or reboot without the ""
Re: Reboot Loop
tozett wrote:flash-erase multiple times in this forum (widespread )
like:Code: Select all
C:\Python27>esptool.py -p COM4 -b 115200 erase_flash Connecting...
Sorry that i act like a dombo..
Only this is higher math for me...
Can i put:
C:\Python27>esptool.py -p COM4 -b 115200 erase_flash [ where i must change my comport ]
Just in my browser?
Re: Reboot Loop
First You must install Python27 : https://www.python.org/download/releases/2.7/Dylantje wrote:tozett wrote:flash-erase multiple times in this forum (widespread )
Can i put:
Just in my browser?
then you must install esptool.py : https://learn.adafruit.com/building-and ... h-firmware
Re: Reboot Loop
Thanks all..
I give up..
try a other board...
Hard to get for me..
I give up..
Re: Reboot Loop
You might try flashing blank.bin. you can search for blank.bin here or google. This essentially clears out the memory so you can flash a new rom. This has worked for me.
These little guys can be really frustrating at times, but I have always been able to get them to work eventually.
Re: Reboot Loop
i've had similar problems when I did an update from R78 to R108.
Directly after flashing the new version I removed power, connected Rx and Tx together.Reconnected power and waited a few minutes so the ESP has time to clear the data memory. Then disconnected power and removed the Rx/Tx short, reconnect power and at that moment the ESP could boot up normally and gave the AP at 192.168.1.4
Re: Reboot Loop
Costo, you have right. Thats a way to work with R108. But for my case i work only with Stable Firmware. I started with R43 the with R77 Martinus introduced update with a bin file. So i bring my 3 devices to R77, A time later R78 came out, I updated with OTA all the 3 devices to R78, no problem at all. Now the latest release R108 i did the same trick en after that i had with all the 3 devices problems. What i have done is clear the flash with clear.ino then load R78 en then via OTA R108. But i have still problems. My 3 devices are 2x ESP-1 and 1x Sonoff. I build the ESP's in a Lamp and AXA windowopener. Now i must remove them,connect them to a pc for updating. I like the OTA feature, but not for me working.costo wrote:i've had similar problems when I did an update from R78 to R108.
- nonflammable
Re: Reboot Loop
I'm not sure if OTA feature works on 512k devices (eg. blue ESP-01)ManS-H wrote:My 3 devices are 2x ESP-1 and 1x Sonoff. I build the ESP's in a Lamp and AXA windowopener. Now i must remove them,connect them to a pc for updating. I like the OTA feature, but not for me working.
Determine the size of the flash chip used on a module you have and then upload correct bin: 512 / 1024 / 4096. http://www.esp8266.nu/index.php/Tutoria ... Flash_size
a few weeks ago, I have uploaded (via OTA) version 4096 to 1024 device ... then there was bootloop
Re: Reboot Loop
My ESP-01 are the black versions, and it works when i go from R77 to R78.nonflammable wrote:I'm not sure if OTA feature works on 512k devices (eg. blue ESP-01)ManS-H wrote:My 3 devices are 2x ESP-1 and 1x Sonoff. I build the ESP's in a Lamp and AXA windowopener. Now i must remove them,connect them to a pc for updating. I like the OTA feature, but not for me working.
Re: Reboot Loop
the Black version is supposed to have 1MB so you are using the "1024" version? According to the change log, OTA never worked on the ESP-01 with 512B, but if you are using the 1024 version for the ESP-01 "Black" modules it should work... I only have 2MB and 4MB modules and I have used OTA on all (about 15) of them with no problems but I don't think I ever used R108.
