ESPEasy statistics access
chromo23
#1 Post by chromo23 » 17 Jan 2025, 09:25
Is there a way to access a specific stats array of a device from the outside? I was thinking about integrating this visually into easyfetch.
Re: ESPEasy statistics access
#2 Post by TD-er » 17 Jan 2025, 09:35
It should, but I just tested it and it doesn't produce valid JSON, so I will have to look into that
You need to add "showpluginstats" as an argument
Like this: http://192.168.10.222/json?sensorupdate ... ginstats=1
#3 Post by TD-er » 17 Jan 2025, 09:45
Ah seems to be a simple error where ",}" is failing the JSON linter.
#4 Post by TD-er » 17 Jan 2025, 10:09
OK, found the bug, will make a commit for it.
You really need to add the =1 to the argument, like this:
http://192.168.11.55/json?showpluginstats=1
chromo23
#5 Post by chromo23 » 17 Jan 2025, 10:12
TD-er wrote: 17 Jan 2025, 10:09 OK, found the bug, will make a commit for it.
Ahh..great. Thanks :)
