ESP32-C6 with built-in TFT
romainperea
#1 Post by romainperea » 15 Jan 2025, 19:00
Hi everyone !
I've ordered this ESP32-C6 board: https://fr.aliexpress.com/item/1005008084095266.html
I have successfully compiled a custom ESPEasy firmware (the 20241222 one), with the P116 plugin, to be able to activate the onboard TFT.
Unfortunatly, the embedded TFT is a 172 x 320 one, driven by a ST7789.
This "configuration" is not available into the included plugin, and to make it "work" a little, i have to access i as a ST7735, with 135 x 240 pixel display attached.
This way, it works but with just a part of the center of the display, and everywhere around, it's like an "old TV fog".
Do you think a "mod" of the P116 version can be made ?
The unit is really interesting, really cheap, integrated display and USB C power/data port.
Thanks in advance !
ps: my project is to make this a temperature sensor (with a DHT22), and the temperature and humidity live displayed on it... I already have a complete DomoticZ system running for years, thanks to you ;) and multiple ESP8266 with DHT22 in 3D printed enclosures
kniazio
Re: ESP32-C6 with built-in TFT
#2 Post by kniazio » 15 Jan 2025, 19:14
Share the compilation. Maybe someone will buy it and there will be more of us.
#3 Post by TD-er » 15 Jan 2025, 21:18
Not sure if the DHTxx sensors are the best choice as they do have their own peculiarities.
For example I've seen those "lock up" when exposed to quite humid weather (e.g. like how it is now in the Netherlands, 200 - 300 m visibility for over 24h and quite cold)
Maybe a BME280 or some other of the many supported sensors is a better choice. See: https://espeasy.readthedocs.io/en/lates ... nvironment
Just make sure to stay away from the AHT1x sensors also... Those cannot be used with any other I2C device on the same bus...
I guess Ton (Ath) will probably reply about the display plugin questions you had..
romainperea
#4 Post by romainperea » 15 Jan 2025, 21:30
I can post my custom firmware here if you want, just tell me what plugin you want inside and i'll do it.
An thanks for the informations about the temperature sensors ;)
#5 Post by Ath » 15 Jan 2025, 22:16
romainperea wrote: 15 Jan 2025, 19:00 Hi everyone !
I've been thinking about switching from TFT library, and also to offer some standard display resolutions, along with an option to configure the desired resolution, as there are more and more slightly different TFT displays available, and it's nearly impossible to try and add all these displays in ESPEasy separately.
Have you tried one of the ST7789 configurations (you can also set the rotation to match the resolution somewhat better), to see if it works better than the ST7735 configuration? For the ST77xx series, the chip setup seems somewhat specific, while the resolution can be set at will, though also some far-east manufacturers seem to sometimes mount different chips then what's mentioned in the documentation. :shock:
romainperea wrote: 15 Jan 2025, 19:00 The unit is really interesting, really cheap, integrated display and USB C power/data port.
There are so many 'interesting display units', it's nearly impossible to test them all, if only for the amount of money it would take to buy a sample of each... :o
And besides that, there are also ESP32-C6 units with 16MB Flash, so you could use the MAX build, thus not requiring a Custom build, but most likely not combined with this display.
romainperea
#6 Post by romainperea » 16 Jan 2025, 09:14
I totally agree, there are so many devices available, an it's not possible to test all of them... I'm gonna try all the possible configurations with the P116 plugin and let you know if one of them works better ;)
romainperea
#7 Post by romainperea » 02 Feb 2025, 16:48
I'll wait for a "future build" for this device ;) (for supporting the embedded display).
Is it possible to "donate" euros for the developpers to buy one of this device to "see" if something is possible ?
#8 Post by Ath » 02 Feb 2025, 16:57
romainperea wrote: 02 Feb 2025, 16:48 I'll wait for a "future build" for this device ;) (for supporting the embedded display).
My signature has a PayPal.me link where you can donate for purchases like these :D
#9 Post by Ath » 02 Feb 2025, 17:03
FYI: Aliexpress is charging me € 15.44 including shipping.
Screenshot - 02-02-2025 , 17_01_50.png (47.62 KiB) Viewed 2217 times
romainperea
#10 Post by romainperea » 02 Feb 2025, 17:32
Done ;)
#11 Post by Ath » 02 Feb 2025, 19:18
Thanks. Order has been finalized. Should ship soon.
romainperea
#12 Post by romainperea » 02 Feb 2025, 21:13
Ath wrote: 02 Feb 2025, 19:18 Thanks. Order has been finalized. Should ship soon.
I'm not sure you'll be able to do something, but it's an interesting device ;)
Users browsing this forum: No registered users and 6 guests
