When I have two 2004 LCD displays connected via I2C with different addresses
The following command manages only one display.
There is no solution that would allow you to control two or more displays separately.
For example, specifying the display name and command to send
Name_LCD_Set_In_ESPEasy,lcdcmd,<value>
Two LCD2004 displays lcdcmd controls only one display
Re: Two LCD2004 displays lcdcmd controls only one display
Close, you need to use a dot ('.') instead of a comma
See: https://espeasy.readthedocs.io/en/lates ... f-a-plugin
Thanks its work!
Please update this page and add info about multiple displays
https://espeasy.readthedocs.io/en/lates ... /P012.html
Great
Well, this is a global feature for any plugin that's being used for multiple tasks and handles commands, so that's why it's documented where it's used/needed most: https://espeasy.readthedocs.io/en/lates ... f-a-plugin1i8x6qmtn wrote: ↑06 Nov 2024, 22:40 Please update this page and add info about multiple displays
Users browsing this forum: Ahrefs [Bot] and 3 guests
