cho51
#1
Post
by cho51 » 04 Jan 2022, 08:29
Hello experts,
i tried to connect a ESPEasy TEST_C to my ESR21-D (VD3.4) without success.
This ESR21-D has not a terminal mounted for DL-BUS but it has the soldering pads.
Here I soldered on a wire and after the voltage devide there is a signal probably ~500Hz as mentioned here:
https://espeasy.readthedocs.io/en/lates ... ight=ESR21.
Does anybody of you have experience with this (probably older) version of ESR21?
Thank you!
Log:
2192099: WD : Uptime 37 ConnectFailures 0 FreeMem 17128 WiFiStatus 3 ESPeasy internal wifi status: Conn. IP Init
2220567: PLUGIN_092_READ Task:0
2220568: P092_read: Still receiving DL-Bus bits!
2222099: WD : Uptime 37 ConnectFailures 0 FreeMem 17128 WiFiStatus 3 ESPeasy internal wifi status: Conn. IP Init
2252098: WD : Uptime 38 ConnectFailures 0 FreeMem 17064 WiFiStatus 3 ESPeasy internal wifi status: Conn. IP Init
2280567: PLUGIN_092_READ Task:0
2280569: P092_read: Still receiving DL-Bus bits!
2282098: WD : Uptime 38 ConnectFailures 0 FreeMem 17064 WiFiStatus 3 ESPeasy internal wifi status: Conn. IP Init
2312098: WD : Uptime 39 ConnectFailures 0 FreeMem 17000 WiFiStatus 3 ESPeasy internal wifi status: Conn. IP Init
2340568: PLUGIN_092_READ Task:0
2340568: P092_read: Still receiving DL-Bus bits!
2342098: WD : Uptime 39 ConnectFailures 0 FreeMem 16920 WiFiStatus 3 ESPeasy internal wifi status: Conn. IP Init
2372098: WD : Uptime 40 ConnectFailures 0 FreeMem 16888 WiFiStatus 3 ESPeasy internal wifi status: Conn. IP Init
2400567: PLUGIN_092_READ Task:0
2400568: P092_read: Still receiving DL-Bus bits!
2402098: WD : Uptime 40 ConnectFailures 0 FreeMem 16840 WiFiStatus 3 ESPeasy internal wifi status: Conn. IP Init
2432098: WD : Uptime 41 ConnectFailures 0 FreeMem 16776 WiFiStatus 3 ESPeasy internal wifi status: Conn. IP Init
2460567: PLUGIN_092_READ Task:0
2460568: P092_read: Still receiving DL-Bus bits!
2462099: WD : Uptime 41 ConnectFailures 0 FreeMem 16712 WiFiStatus 3 ESPeasy internal wifi status: Conn. IP Init
2492099: WD : Uptime 42 ConnectFailures 0 FreeMem 16632 WiFiStatus 3 ESPeasy internal wifi status: Conn. IP Init
2520568: PLUGIN_092_READ Task:0
2520569: P092_read: Still receiving DL-Bus bits!
2522098: WD : Uptime 42 ConnectFailures 0 FreeMem 16440 WiFiStatus 3 ESPeasy internal wifi status: Conn. IP Init
2552099: WD : Uptime 43 ConnectFailures 0 FreeMem 16440 WiFiStatus 3 ESPeasy internal wifi status: Conn. IP Init
2580567: PLUGIN_092_READ Task:0
2580568: P092_read: Still receiving DL-Bus bits!
2582098: WD : Uptime 43 ConnectFailures 0 FreeMem 16440 WiFiStatus 3 ESPeasy internal wifi status: Conn. IP Init
2612099: WD : Uptime 44 ConnectFailures 0 FreeMem 16440 WiFiStatus 3 ESPeasy internal wifi status: Conn. IP Init
firmware:
ESP_Easy_mega_20211224_test_C_ESP8266_4M1M Dec 24 2021
- DL-BUS.JPG (3.34 MiB) Viewed 9293 times
cho51
#2
Post
by cho51 » 04 Jan 2022, 09:50
Manufacturer TA told me, that ESR21 supports DL-BUS with firmware version 5.0 and newer.
My older devices (V4.1 and V3.4) do not send out measurement data...
ESR31: a friend uses a ESR31 VD 3.3 with ESPEasy TEST_C.
cho51
#3
Post
by cho51 » 04 Jan 2022, 10:03
ESR31 supports DL-Bus starting with version 1.0 (info by TA)
cho51
#4
Post
by cho51 » 04 Jan 2022, 10:06
SUMMARY about ESPEasy and ESR21/ESR31:
ESR21 VD 5.0 and newer are supported
ESR31 VD 1.0 and newer are supported
#5
Post
by Ath » 04 Jan 2022, 10:21
And it looks like there is no way to update these devices' firmware (at least I couldn't any firmware updates at the TA site), that's a pity.
cho51
#6
Post
by cho51 » 31 Jan 2022, 14:52
I bought a used ESR21 V5.9 and it works quite fine with TEST_C 20211224...
#7
Post
by Ath » 31 Jan 2022, 15:05
Great
gecko
#8
Post
by gecko » 03 Nov 2024, 16:09
cho51 wrote: ↑04 Jan 2022, 10:03
as I am trying to read out the ESR31 via the DL Bus, does this mean, the ESR31 is already included on the P092 plugin? I am an interested newbie and I have set up an ESP8266 with Collection-C and this is as far as I got. Well actually I have also soldered a voltage divider even though I am not sure that I need it and I have connected the DL Bus to the 8266 (Ground and GPIO14=D5). And this is exactly as far as I got. My final goal would be to connect with home assistant. But I guess I am stuck right now, I don‘t get any values back. What number do I have to provide in data source / remote unit? I lack too much knowledge I guess …
Best Regards Gerhard
#9
Post
by Ath » 03 Nov 2024, 16:25
gecko wrote: ↑03 Nov 2024, 16:09
Hmm, P092 supports ESR21 and UVR31. Not sure if that includes your ESR31?
I assume you enabled the task, selected the desired device type, and a data field that actually has some data (not 0 ) available?
What Interval have you set the task to? As waiting for 60 seconds between a measurement can be frustratingly long...
Edit: The ESR21 setting should also support ESR31.
