The 6050 plugin is fantastic and has a well designed motion detection. My only grief is that it is hard to tune the values for motion because I haven't found a way to track more than one axis at a time.
Is there any way to plot both X/Y/Z accelleration on a single graph?
Track multiple axis with Gyro 6050
Re: Track multiple axis with Gyro 6050
Have you tried to enable 'stats' for the taskvalues?
Yes stats is amazing but the plugin only lets you select one value, unless I missed something. Been able to see stats for either X/Y or Z axis but not all of them.
Ah check, then I have to look at the code to see what is possible here. If possible, then it probably needs some code change.
I've also made it more practical for the ADXL345
that would incredible - btw the stat feature blew my mind it is so well designed... you can do all the data collection and threshold analysis straight in letscontrolit
Hi @OttawaHacker,OttawaHacker wrote: ↑23 Oct 2024, 18:04 The 6050 plugin is fantastic and has a well designed motion detection. My only grief is that it is hard to tune the values for motion because I haven't found a way to track more than one axis at a time.
I've created a Pull request #5151 to optionally have all 3 axis X/Y/Z values available for the selected measurement (Range acceleration, Acceleration, G-force). The values are always in X/Y/Z order. To see all 3 values you'll first have to submit the settings page with the 'Provide all 3 values (X/Y/Z)' checkbox enabled.
This setting is not currently applicable to Movement detection.
You can download a test build from this GH Actions run (You'll need a free Github account to be able to download from there).
