P159 LD2410 Radar Presence Sensor
azonneveld
#1 Post by azonneveld » 14 Sep 2024, 22:30
To disable a gate, one should enter the maximum value for sensitivity: 100.
But this value is reached when an object is very clear, and therefor the disable is not working.
Please allow the maximum value for a gate to be set to >100, so it will never be reached.
Or f.i. add a disable/enable boolean to each gate
For now I mitigate the issue by using rules, but that's a 'dirty' solution.
Sensitivity, Gate 0 .. 8: For each type of detection, the sensitivity treshold can be set, range 0 .. 100, where 0 is the most sensitive, and 100 means it won’t trigger,
see: https://espeasy.readthedocs.io/en/lates ... /P159.html
bidrohini
Re: P159 LD2410 Radar Presence Sensor
#2 Post by bidrohini » 09 Oct 2024, 17:10
You can Implement a boolean toggle for each gate. That would give you more flexibility.
#3 Post by Ath » 09 Oct 2024, 21:23
azonneveld wrote: 14 Sep 2024, 22:30 To disable a gate, one should enter the maximum value for sensitivity: 100.
The max value of 100 is according to the documentation, extracted from the source code and the spec sheet.
What actual values are you getting from your sensor?
azonneveld wrote: 14 Sep 2024, 22:30 For now I mitigate the issue by using rules, but that's a 'dirty' solution.
Also taken from that mentioned documentation.
These sensors are very sensitive (pun intended), and also respond to reflected signals and similar sensors nearby like car radar distance sensors, and even a micro-wave being used somewhat nearby.
Shielding the device from false triggers can be quite hard, and may even need adjustments over time.
Can you show your current configuration?
#4 Post by Ath » 09 Oct 2024, 23:15
azonneveld wrote: 14 Sep 2024, 22:30 Please allow the maximum value for a gate to be set to >100, so it will never be reached.
I've increased the max. sensitivity setting to 110 in PR #5140, builds available in this Github Actions run.
@azonneveld Can you please test if this increased threshold is a) working as intended, and b) is enough to suppress the undesired triggers you've experienced?
#5 Post by Ath » 28 Oct 2024, 21:26
@azonneveld Have you been able to test with the extended threshold? And if so, is this enough to avoid the issue?
Users browsing this forum: Bing [Bot] and 0 guests
