How to change the AP mode SSID "ESP_Easy_0"
dino
#1 Post by dino » 16 Jun 2020, 20:23
as mentioned in the topic, how can I change the default AP SSID "ESP_Easy_0" and the password to something else?
Thanks in advance,
dino
Re: How to change the AP mode SSID "ESP_Easy_0"
#2 Post by grovkillen » 16 Jun 2020, 20:55
The SSID is made from the unit name and number. But if you want to make it something completely different you need to compile your custom version.
#3 Post by TD-er » 16 Jun 2020, 22:12
And you can change whether the unit number is appended or not in the settings.
etardioli
#4 Post by etardioli » 11 Sep 2024, 23:31
Hi!! Where can i change this values?
#5 Post by TD-er » 11 Sep 2024, 23:52
On the config tab
You can set the host name and unit nr.
Users browsing this forum: Google [Bot] and 1 guest
