PID 0xA060
FW 159
SER# HQ21069E3M5
V 26280
I 750
VPV 31920
PPV 20
CS 3
MPPT 2
OR 0x00000000
ERR 0
LOAD OFF
PID 0xA060
FW 159
SER# HQ21069E3M5
V 26280
I 750
VPV 31920
PPV 20
CS 3
MPPT 2
OR 0x00000000
ERR 0
LOAD OFF
The documentation isn't rich on examples, but the basic information is available: https://espeasy.readthedocs.io/en/lates ... #p087-pagemgrunt wrote: ↑13 Jul 2024, 12:40 Hi, how can I get for example value "V" from this stream?
I've tried everything but it doesn't work. Thank you.Code: Select all
PID 0xA060 FW 159 SER# HQ21069E3M5 V 26280 I 750 VPV 31920 PPV 20 CS 3 MPPT 2 OR 0x00000000 ERR 0 LOAD OFF
(%w+#?)%s+(%w+)
On *serialproxy#v Do
LogEntry,'Match P1: [serialproxy#group.0], P2: [serialproxy#group.1] V: [serialproxy#next.V] ERR: [serialproxy#next.ERR]'
If {equals:V:'[serialproxy#group.0]'}=1
LogEntry,'Processing V value: [serialproxy#group.1]'
Endif
If {equals:ERR:'[serialproxy#group.0]'}=1
LogEntry,'Processing ERR value: [serialproxy#group.1]'
Endif
It's quite hard to write good documentation, and having a real-world example is really helpful. I'll see how I can use this for documentation.
To reduce the load on the ESP we don't currently log all received data. I could add an option to the settings, but when leaving the regular expression empty it is supposed to pass through all incoming data to Rules, where you can process it, including writing it all to the log.
PID 0xA053
FW 164
SER# HQxxxxxxxxx
V 26280
I 750
VPV 31920
PPV 20
CS 3
MPPT 2
OR 0x00000000
ERR 0
LOAD OFF
IL 0
H19 5298
H20 68
H21 485
H22 75
H23 517
HSDS 245
Checksum
1664663830: EVENT: serialproxy#v=`H21)135`
1664670793: EVENT: serialproxy#v=`CS)3`
1664677816: EVENT: serialproxy#v=`ERR)0`
1664683808: EVENT: serialproxy#v=`PPV)16`
1664705265: EVENT: Clock#Time=Tue,14:26
1664717921: EVENT: serialproxy#v=`MPPT`
1664717937: EVENT: serialproxy#v=`2`
1664761938: EVENT: serialproxy#v=`PPVI16`
1664762911: EVENT: serialproxy#v=`V`
1664762933: EVENT: serialproxy#v=`13000`
1664763973: EVENT: serialproxy#v=`H19I764t`
1664765264: EVENT: Clock#Time=Tue,14:27
1664765913: EVENT: serialproxy#v=`FW`
1664766060: EVENT: serialproxy#v=`164`
1664768968: EVENT: serialproxy#v=`IL`
1664768989: EVENT: serialproxy#v=`2300`
1664792016: EVENT: serialproxy#v=`IL`
1664792035: EVENT: serialproxy#v=`2300`
1664792953: EVENT: serialproxy#v=`PIDI0xA053`
1664800991: EVENT: serialproxy#v=`I`
1664801011: EVENT: serialproxy#v=`-1180`
1664816054: EVENT: serialproxy#v=`LOAD)ON`
1664818082: EVENT: serialproxy#v=`HSDS)269`
1670252457: EVENT: serialproxy#v=`SER#IHQXXXXXXXX`
1670252462: ACT : LogEntry,'Match P1: , P2: V: ERR: '
1670252474: Match P1: , P2: V: ERR:
1670252477: Calculate: Unknown token
1670252482: Calculate: Unknown token
1670252513: EVENT: serialproxy#v=`22`
1670252518: ACT : LogEntry,'Match P1: , P2: V: ERR: '
1670252529: Match P1: , P2: V: ERR:
1670252533: Calculate: Unknown token
1670252538: Calculate: Unknown token
The input is already split on any <CR> received, so that shouldn't be an issue. Similar for a ^ at the start of the regex.
That log will only work if the regex is processed, and that processing is skipped (to improve processing speed) if you disable the regex/filtering in the settings.
Once you enable the regex, it will ignore that Checksum line, as it probably doesn't have a white-space separator and is missing the second token.
50748446: Command unknown: FW164
50748455: Command unknown: SER#HQXXXXXX
50749376: Command unknown: Checksum
50749455: Command unknown: 543CR7
50749463: Command unknown: V13130
50750376: Command unknown: PID0xA053
50750458: Command unknown: 213543CR7
50750466: Command unknown: V13130
50751380: Command unknown: PID0xA053
50751399: Command unknown: CR7
50751473: Command unknown: CS3
50752379: Command unknown: PID0xA053
50752449: Command unknown: FW164
50752519: Command unknown: SER#HQXXXXXX
50752525: Command unknown: SDS270
50753390: Command unknown: FW16
50753471: Command unknown: 1440
50753479: Command unknown: VPV17910
50754393: Command unknown: PID0xA05164
50754524: Command unknown: SER#HQXXXXXX
50755385: Command unknown: PID0xA053
50755465: Command unknown: SER#HQXXXXXX
50755534: Command unknown: 18400
50756388: Command unknown: PID0xA053
50756467: Command unknown: 3CR7
50756475: Command unknown: V13130
50757386: Command unknown: A053
50757458: Command unknown: FW164
50757529: Command unknown: SER#HQXXXXXX
50757535: Command unknown: 70
50758386: Command unknown: D0xA053
50758396: Command unknown: FW164
50758469: Command unknown: 13130
50758537: Command unknown: 270
50759395: Command unknown: Checksum0xA053
50759415: Command unknown: 3130
50759488: Command unknown: MPPT2
50760396: Command unknown: PID
50760467: Command unknown: SER#HQXXXXXX
50760537: Command unknown: V13130
50761386: Command unknown: ecksum
50761457: Command unknown: PID0xA053
50761466: Command unknown: F164
50761534: Command unknown: H23141
50761603: Command unknown: HSDS270
50762388: Command unknown: Checksum
50762458: Command unknown: PID0xA053
50762467: Command unknown: FW164
50762545: Command unknown: H23141
50762614: Command unknown: HSDS270
PID 0xA053
FW 164
SER# HQXXXXXX
V 26280
I 750
VPV 31920
PPV 20
CS 3
MPPT 2
OR 0x00000000
ERR 0
LOAD OFF
IL 0
H19 5298
H20 68
H21 485
H22 75
H23 517
HSDS 245
Checksum
