Is there something wrong in the config of my LAN, Router or Accesspoint? Some other devices are named correct.
![Bedroeft :(](./images/smilies/icon_e_sad.gif)
![Image](https://i.ibb.co/wpvdBM9/Screenshot-20240526-101808-Chrome.jpg)
Has a relation with the config of hostname I suppose? Unit Name in tab Config is SDM630M_Teslalader
![Image](https://i.ibb.co/JtvQwRK/Hostname.jpg)
What could be a solution?
Well, TD-er already wrote a possible cause above; when using a fixed IP address, the ESP plainly connects to the router, claiming the configured IP-address, not sharing much other information except the (required) MAC address.
Also some RFC's supersede older ones, which can also cause some conflicting definitions or specs.(Request For Comments) A document that describes the specifications for a recommended technology. Although the word "request" is in the title, if the specification is ratified, it becomes a standards document. Not all RFCs become standards; some are designated indefinitely with Informational or Experimental status.
Most routers also act as local DNS server.
