check if the mqqt server is present
edstobi
#1 Post by edstobi » 26 May 2024, 17:02
I would like to equip my ESP 32 with a safety function.
I am using a WT32-eth01 with LAN and if this is not present then wifi.
Now I want to check if the mqqt server is present. If the server is not reachable because of a malfunction or newnetwork problems, all gpios which control relays, have to go into a defined position to prevent damage.
GPIO,4,1
GPIO,5,1
GPIO,14,1
GPIO,15,1
Can I make a ping request or a secure request to the MQTT server and initiate the shutdown process if this is not answered?
I am running ESP_Easy_mega_20230930_normal_ESP32_4M316k_ETH.
trying a ping I am getting
Command unknown: ping 10.10.10.10 // IP from MQTT it responds on pin from PC
Re: check if the mqqt server is present
#2 Post by Ath » 26 May 2024, 20:53
For this purpose there are the MQTT#Connected and MQTT#Disconnected events.
When receiving the mqtt#disconnected event you can start any precautious measures needed, and revert them once the server is connected again.
edstobi
#3 Post by edstobi » 26 May 2024, 21:48
thank you
that sounds like the right way to go
how can i query this in a rule?
can I simply do this with:
On MQTT#Disconnected Do
GPIO,4,1
GPIO,5,1
GPIO,14,1
GPIO,15,1
I have just found the answer to this question myself in the help section.
But I do not check the differentes between MQTTimport#Disconnected and MQTT#Disconnected :(
#4 Post by Ath » 26 May 2024, 21:59
MQTTImport#Disconnected has to do with the MQTT Import plugin P037, and is, sort of, independent from the MQTT#Disconnected event. (IMHO) you can ignore the MQTTImport events for this.
#5 Post by TD-er » 26 May 2024, 22:00
mqtt#disconnected as also MQTT import uses the MQTT broker settings of the first enabled MQTT controller.
jgrad
#6 Post by jgrad » 27 May 2024, 13:08
there is also system variable %ismqtt%
#7 Post by Ath » 27 May 2024, 14:23
jgrad wrote: 27 May 2024, 13:08 there is also system variable %ismqtt%
Well, when would you check that variable? You'd have to add some repeating event to check that, so responding to the original event seems more natural and appropriate.
jgrad
#8 Post by jgrad » 27 May 2024, 15:17
I just wanted to add if events are not enough that related to this topic there is also system variable available....
#9 Post by Ath » 27 May 2024, 15:47
