ESP Easy 32-C3 workaround to prevent crash
BartSr
#1 Post by BartSr » 25 May 2024, 18:46
Maybe others can have benifit of my workaround.
I'm having the IKEA airqualitysensor and modified it to get data into domoticz using easpeasy.
I used ESP Easy 32-C3 to built in. This worked using mqtt.
but..
load increased rapidly until the device crashed.
my workaround is to use a rule like:
On System#Boot do    // When the ESP boots, do
   LoopTimerSet,1,60  // Set Timer 1 for the next event in 60 seconds
On Rules#Timer=1 do
   Let,1,[Lucht#PM2.5]
  SendToHTTP 192.168.2.100,8080, '/json.htm?type=command&param=udevice&idx=1102&svalue=[var#1]'
so no mqtt controller required and for me a solution already working well now for a week.
Re: ESP Easy 32-C3 workaround to prevent crash
#2 Post by TD-er » 25 May 2024, 21:57
Which build were you using for the C3 as I don't recognize these issues.
Also what version of MQTT broker are you using? Maybe there has been some changes in some MQTT broker which require some changes for ESPEasy as it might get disconnected all the time?
