The temperature offset seems consistent for this sensor, as I see a similar delta. The intended use of the sensor is for temperature compensation of the measurements, not to supply the ambient temperature value
when configured for Ikea Vindstyrka, an additional compensation is applied in the code, for the extra heat the ESP adds inside the housing...
Ii didn't add a setting for that, as you can use a formula to subtract the offset, but if you think it's really useful, I can add such setting?
You have configured 2 tasks with different output values, that was required by the old plugin implementation, but I changed the original implementation to now be independent tasks, so not sure if that's a good idea, 2 tasks trying to control the same device...
The advantage of allowing multiple, independent tasks, is that you can have multiple independent sensors on a single ESP, when using an I2C multiplexer (because it has a fixed I2C address). That multiplexer is supported in nearly all ESPEasy builds (See the Hardware tab).
My addition of Get Config Values implementation, allows to fetch all values from a
single task instance, and the intended solution to make them visible on the Device page is to use a Dummy Device, that gets it's values set using a rule that responds to an event of this task, like this:
// Change #Temperature to #All if "Single event with all values" is enabled
On SEN55#Temperature Do // This assumes a Dummy Device named SEN555, with Quad Values: PM1p0, PM2p5, PM4p0 and PM10p0
TaskValueSet,SEN555,PM1p0,[SEN55#PM1p0]
TaskValueSet,SEN555,PM2p5,[SEN55#PM2p5]
TaskValueSet,SEN555,PM4p0,[SEN55#PM4p0]
TaskValueSet,SEN555,PM10p0,[SEN55#PM10p0]
The results will be exactly the same, as during measurement all values are retrieved from the sensor (Ikea-mode receives them every second, as that's the update frequency of the Vindstyrka), so are always all available at the same time.
NB: After starting the plugin the first couple of measurements may show some unexpected/0 results, as the sensor seems to do some averaging before returning some values, like tVoc and NOx.
