LILYGO T4-S3 ESP32-S3
bastler11
#1 Post by bastler11 » 18 Apr 2024, 10:56
would it be possible to run and ESP Easy on the LILYGO T4-S3 ESP32-S3 board and control over ESP Easy the display?
Thanks and best regards!
Re: LILYGO T4-S3 ESP32-S3
#2 Post by TD-er » 18 Apr 2024, 11:00
Not sure if the AMOLED display needs some specific controller which might not yet be supported.
https://www.lilygo.cc/products/t4-s3
I guess Ton will probably know more about this :)
#3 Post by Ath » 18 Apr 2024, 11:06
What version of that board do you have in mind? There are a couple of different versions, also quite different in price ($30,- .. $75,-) ... :o
At the moment the display controller in those boards isn't supported (it's not using 'standard' SPI but a 4 or 8 bit parallel connection), but there has been some interest in it, also via other channels ;)
The GT911 touch controller is not yet supported, but is on the Planned Plugin List (PPL), waiting for a generic ESPEasy touch-screen handler to be merged.
bastler11
#4 Post by bastler11 » 18 Apr 2024, 11:51
I had a look on this board:
https://www.amazon.de/dp/B0CRYJC3NW/
One more question: how could I get an information that somebody answers on my question, is there a switch in the settings?
#5 Post by TD-er » 18 Apr 2024, 11:57
What kind of switch in the settings do you mean?
#6 Post by Ath » 18 Apr 2024, 14:59
bastler11 wrote: 18 Apr 2024, 11:51 One more question: how could I get an information that somebody answers on my question, is there a switch in the settings?
If you go to your User Control Panel (dropdown menu top-right, next to your username), Select 'Board Preferences', then 'Edit notification options', you can determine what notifications you receive and how to receive them, and also when writing a new Topic, then you can select or de-select to receive a notification on responses ('Notify me when a reply is posted').
bastler11
#7 Post by bastler11 » 18 Apr 2024, 15:29
Thanks, now it works 🤪
#8 Post by Ath » 22 Apr 2024, 10:57
bastler11 wrote: 18 Apr 2024, 11:51 I had a look on this board:
Have you seen the real-world dimensions of that display? (the images are somewhat misleading, IMHO) It's only 44mm wide, and 56mm high. And with that 480x600 resolution could result in very small text being displayed :shock:
bastler11
#9 Post by bastler11 » 22 Apr 2024, 11:29
Yes, it is not so big, but I thought it better than the OLED SSD1306? On the other side it is a little bit expensive.
Users browsing this forum: Google [Bot] and 1 guest
