One button code lock
Re: One button code lock
#51 Post by Ath » 26 Oct 2023, 11:30
Why is this in your log?
Command unknown: 1=11 and 1=3
Something strange in your rules?
Dick60
#52 Post by Dick60 » 26 Oct 2023, 12:31
Thanks for the tip, I checked the code and now is this part working.
I typed Elseif and not Else if.
Here the correct code
on Switch#State do
 if %eventvalue1%=1
 let,1,[int#1]+1 // Count pulses
    timerset,1,1 // Set timer to clear the counter
  if  %eventvalue1%=11 and [int#1]=3
    // Accept the code
    let,1,0 // Clear counter
   GPIO,12,0
on rules#timer=1 do
Dick60
#53 Post by Dick60 » 26 Oct 2023, 16:57
Is it possible, instead of counting only the button pushes, to sum the value of the GPIO. For example: 2 short and 2 long results in a 24 (1+1+11+11) so I can do something with the value of the sum and the number or pushes. (switch on an led or something. This is my setup, sofar. The problem is that GPIO,12,0 is not executed. I see both the long and short pulses, the reset of the Variables by Timer 1 but no execution of GPIO,2,0.
on Switch#State do
 if %eventvalue1%=1
    timerset,1,1 // Set timer1 to clear the counter
if  %eventvalue1%=11
let,2,[int#2]+1 //Count long press
timerset,1,1
  if  [int#2]=2 and [int#1]=5 //2 long and 3 short
    // Accept the code
    let,1,0 // Clear counter 1
    let,2,0 // Clear counter 2
   GPIO,12,0
timerset,2,5 //Set timer 2 to turn off led
on rules#timer=1 do
  let,2,0 //Clear counter 2
on rules#timer=2 do
  GPIO,12,1
Dick60
#54 Post by Dick60 » 27 Oct 2023, 11:25
After a lot of testing, the final script is working . I played with the timer and this is the final working solution:
on Switch#State do
 if %eventvalue1%=1
    timerset,1,3 // Set timer to clear the counter
  elseif %eventvalue1%=11
let,2,[int#2]+1 //sum long press
timerset,1,3
  if  [int#2]=1 and [int#1]=2 //1 long and 1 short
    // Accept the code
   GPIO,12,0
timerset,2,5
on rules#timer=1 do
  let,2,0
on rules#timer=2 do
  GPIO,12,1
Dick60
#55 Post by Dick60 » 25 Nov 2023, 11:27
Is there already some time for reviewing and optimization of the E-button plugin? If not, see it as a reminder.
Dick60
#56 Post by Dick60 » 16 Apr 2024, 08:01
Anyone time for optimizing the Ibutton plugin?
