Sonoff MS01 value
Micha_he
Sonoff MS01 value
#1 Post by Micha_he » 12 Apr 2024, 19:59
I've tested a Sonoff MS01 with the latest release.
But I didn't get any humidity-value and a temperature from ~28000 !?
Is this the raw-value from the sensor and the plugin isn't work/calcutate the temperature-/humidity-value?
Tested with "ESP_Easy_mega_20240331_normal_WROOM02_2M256.bin" image.
Re: Sonoff MS01 value
#2 Post by Ath » 12 Apr 2024, 20:53
It looks like ESPEasy provides the raw measurement value indeed, but looking at the Tasmota code, where the ESPEasy code is based on, they don't provide a temperature value but 0. Don't know why the raw value is provided here, but I suggest to ignore it, as it isn't useful.
The humidity is calculated from that raw value, so I'd expect some useful data there, but you may need a couple of decimals for usability.
Micha_he
#3 Post by Micha_he » 13 Apr 2024, 09:02
I didn't understand you completely. With decimals you mean the decimalplaces of the value? The are no decimalplaces!
Micha_he
#4 Post by Micha_he » 14 Apr 2024, 10:15
It looks, that the (from plugin) calculated value (sensor at air) is <0.
If I put it in the ground, I get a humidity-value. A little low, but it works.
Users browsing this forum: Google [Bot] and 2 guests
