How to set up value open/close
Hi. Is it possible using Switch input - Switch to set value Open/Close not 0/1?
I'm trying to do the door lock status sending via mqtt to Nettemp. In nettemp i can receive status open/close.
Re: How to set up value open/close
The use of variables supports formatting like that, as documented here: https://espeasy.readthedocs.io/en/lates ... red-values
so, your rule could use it like this:
NB: If you want to send a 'state' (Closed/Open) instead of an 'action' (Close/Open) the 'C' transformation should be changed to 'c'.
If 0 means open, and 1 means close, then the transformation should be prefixed with an exclamation mark, so '!C' or '!c' (no quotes should be used for the transformation in the actual rules code, that's just added for readability)
It is currently not (easily) supported to send a transformed value to a controller, so the Controller checkbox on the task should be disabled, as it is sent from rules now.
on switch#state do // Adjust switch and state to the name of your Device task
Publish,topic/goes/here,[switch#state#C#c] // Adjust also when applicable, sends 'Close' and 'Open' ('C' transformation), with first character capitalized, rest in lower case because of the 'c' justification
thank You! I will try:)
after almost one year i have back to this topic.
In link which you posted I found what you meaned.
C: 0 => “CLOSE” 1 => “ OPEN”
c: 0 => “CLOSED” 1 => “ OPEN”
I have been tried something like this:
but in [switch#state#C] i have nothing.
What I'am missing?
on Door_sensor#State do
Publish,homedoor_1,Door_sensor,State,[switch#state#C]
1280172: EVENT: Door_sensor#State=0
1280187: ACT : Publish,homedoor_1,Door_sensor,State,
1284790: EVENT: Door_sensor#State=1
1284801: ACT : Publish,homedoor_1,Door_sensor,State,
- switch.jpg (16.52 KiB) Viewed 1209 times
2022, that's even 2 years ago
Well, that's to be expected, your switch is called Door_sensor...nobody@all wrote: ↑29 Mar 2024, 00:18but in [switch#state#C] i have nothing.Code: Select all
on Door_sensor#State do Publish,homedoor_1,Door_sensor,State,[switch#state#C] endon
What I'am missing?
This should work:
Publish,homedoor_1,Door_sensor,State,[Door_sensor#state#C]
You might also need to use quotes as the " OPEN" has a space in it.
And you have too many commas for the MQTT topic.
Typically you have to use / as separator for topic levels.
Maybe this is better:
Publish,homedoor_1/Door_sensor/State,"[Door_sensor#state#C]"
if %eventvalue%=0
Publish,homedoor_1/Door_sensor/State,CLOSE
Publish,homedoor_1/Door_sensor/State,OPEN
I finally know why my wife is always angry at me - I think I'm doing it quickly but in real two year passed like a one day
this code
work great. thank You
this code
if %eventvalue%=0
