Value checking in Rules sometines don't work
Stef2s
#1 Post by Stef2s » 25 Mar 2024, 21:05
I've just started with EspEasy, looks great, but I have some problems with tyhe Rules section
I use the Dummy plugin P033 with the name "Dummy" and first parameter named "Value"=199, compiled with sources of 20231225.
(I didn't see a change related to this problem in the newer released software)
I've the following Rules:
On Dummy#Value > 100 Do
LogEntry,"Test1"
On [Dummy#Value] > 100 Do
LogEntry,"Test2"
On Dummy#Value Do
LogEntry,"Test3"
If Dummy#Value > 100
LogEntry,"Test4" // giving Error : Calculate: Unknown token input: dummy#value = 0
If [Dummy#Value] > 100
LogEntry,"Test5"
LogEntry,"Test6"
And the result is:
01:12:53.583 : (215656) Info : Dummy: value 1: 199.00
01:12:53.595 : (215516) Info : EVENT: Dummy#Value=199.00
01:12:53.611 : (215420) Info : ACT : LogEntry,"Test3"
01:12:53.615 : (215372) Info : Test3
01:12:53.618 : (215356) Error : Calculate: Unknown token input: dummy#value = 0
01:12:53.628 : (215420) Info : ACT : LogEntry,"Test5"
01:12:53.632 : (215372) Info : Test5
01:12:53.635 : (215420) Info : ACT : LogEntry,"Test6"
01:12:53.639 : (215372) Info : Test6
Why aren't Test1, Test2 and Test4 not working ?
cheers, Stef
Re: Value checking in Rules sometines don't work
#2 Post by Ath » 25 Mar 2024, 22:22
Stef2s wrote: 25 Mar 2024, 21:05 Why aren't Test1, Test2 and Test4 not working ?
That's the difference between using square brackets or not:
- For event handlers do NOT use square brackets
- For variable values to be used DO use square brackets
This is the intended and documented behavior ;)
#3 Post by Ath » 25 Mar 2024, 22:43
There's actually another issue with your rules.
Once a matching rule is found, rules processing is stopped to (greatly) improve performance.
This implies that test2 and later will only be reached if [Dummy#Value] is less than 100. Best way to handle a variable that has to be checked for multiple values, is to have the generic handler, like your test3 situation, and check for all (corner-)cases you need to handle.
And you could wrap your rules examples in code tags (the </> button in the forum toolbar) (and add some indenting spaces for readability please):
On Dummy#Value > 100 Do // --> This could be valid
  LogEntry,"Test1"
On [Dummy#Value] > 100 Do // --> This variable is replaced when loading the rules into memory, and won't be parsed again, so most likely won't work as expected
  LogEntry,"Test2"
On Dummy#Value Do // --> This is probably the best way to handle multiple values
  LogEntry,"Test3"
  If Dummy#Value > 100 // --> Variable values will be used when the task value is wrapped in square brackets: [taskname#valuename]
  If [Dummy#Value] > 100 // --> This is a valid test
    LogEntry,"Test5"
  LogEntry,"Test6"
Stef2s
#4 Post by Stef2s » 26 Mar 2024, 00:19
thanks for the answers Ath
first of all I didn't know how to insert code in to this message, so I'll try again
I now understand the use of [] thanks !
And for the moment I assume that it's not possible to test for a specific value in the On .. Do clause directly.
On Dummy#Value > 100 Do   // <-- this isn't allowed, I guess, although there is an example "on PIR#State=1 do"
    LogEntry,"Test1"      // so this is never executed
cheers, Stef
#5 Post by TD-er » 26 Mar 2024, 08:50
There are some limitations on comparing the value in the on...do clause.
Also you have to keep in mind the rules parsing stops at the first matching rules block.
Best practice is to do the compares inside the rules block, like this:
On Dummy#Value Do
  if %eventvalue1% > 100
    LogEntry,"Test1, %eventvalue1% > 100"
    LogEntry,"Test2, %eventvalue1% <= 100"
