In-soil/Underground application of SHT1x & DS18B20
Re: In-soil/Underground application of SHT1x & DS18B20
#51 Post by TD-er » 27 Jan 2024, 22:11
PoE is running at around 50-ish Volt, so even less current through the wires.
Ton_vN
#52 Post by Ton_vN » 28 Feb 2024, 09:21
Nice weather enables opening and inspection of the boxes of the setup.
Visual signs of shortcircuit in the circuitry of the capacitive fork, probably due to intrusion of water/condensation:
at location where those effects first could be expected ....
That is probable cause of the earth-short mentioned in earlier messages, kicking out the related 230V-group,
because now the power supply etc. restarts without problem.
CapFork_watershortcircuit
Have 'raised' the DS18B20-array and presently rebuilding for 'underground'-configuration with 5*DS18B20 and 4*PWM-sensor.
Users browsing this forum: No registered users and 28 guests
