I have installed ESPEasy_test_C_ESP8266_4M1M on D1 Mini, but under Tasks i cannot find the device "Heating - DL-Bus (Technische Alternative)".
It should be the right version. (Test C)
What I am doing wrong?
BR
Max
Heating - DL-Bus (Technische Alternative) not found
Re: Heating - DL-Bus (Technische Alternative) not found
It is indeed mentioned in the "Testing C" build, but the "Limit build size" disables it.
So it is (sadly) correct that it is not present in that build.
I will make it available in the next build.
I will try if it will fit in either the "testing C" or "energy" build.
Made a build where it should be included: https://www.dropbox.com/s/63cdwhnty6olr ... M.bin?dl=0
I was also looking at this, but you already got this, so I won't PR anything. Unless you want me to
Well you made the split, so I guess you're the perfect man for the job
Thanks a lot. I flashed it now and the device is available
I hope it works with the UVR1611. I'll tell you later
BR
Max
BR
Max
Hi all,
does the ESPEasy DL-Bus plugin also support the master device functionality for the Cora DL-bus, i.e. is it possible to directly connect a DL-bus sensor device like the TA Fristar 3 WP to ESPEasy. With "direct connect" I mean without using a TA UVRxy and/or TA CMI.
I want to connect my TA Fristar 3 WP to my smart home system using espeasy in order to read/wrote cora-dl bus variables.
Users browsing this forum: Semrush [Bot] and 38 guests
