something foundational?
Moderators: grovkillen, Stuntteam, TD-er, enesbcs
uxhamby
#1 Post by uxhamby » 16 Jan 2024, 02:23
In RPiEasy, is there something foundational I need to do, prior to the use 'Clock#Time' within 'RULES' ?
on Clock#Time=All,**:30 do //will run every hour at the half hour
  taskrun,Ambient
  timerSet,1,60
I am not seeing any action with rules that I know work in ESPEasy. Also, I don't see any Clock#Time events in the RPiEasy log either.
Thanks,
Brian H.
bidrohini
Re: something foundational?
#2 Post by bidrohini » 19 Jan 2024, 16:49
Ensure that the timezone is correctly configured in RPiEasy. If the timezone is not set correctly, it might affect the triggering of time-based events.
uxhamby
#3 Post by uxhamby » 23 Feb 2024, 04:03
Thanks for the suggestion.
I have verified that TZ is set properly on the RPi via raspi-config, but don't see any of the usual time settings on the Tools/Advanced page as I am used to in ESPEasy, nor any other means of making a TZ setting within RPiEasy.
Cheers,
Brian H.
