"WindowsEasy"
martinus
"WindowsEasy"
#1 Post by martinus » 18 Jan 2024, 14:40
As i have really grown to use the rules engine on my ESP devices and also quickly navigate between ESP units to manage my home even without a central home automation system, i wanted to integrate my Windows Hosts into this 'eco system' as well.
So i've build a PowerShell based prototype to provide a simple webgui and rules engine with a similar approach and look and feel as the ESP nodes. They will communicate through MQTT, but the Windows node will also manage the nodelist updates using UDP messages.
So here is the first working prototype in action:
Now i can control the Virtual machines that run on the Hyper-V hosts from a webpage button or from events using MQTT. So in theory an ESP unit could start or stop a Virtual Machine.
I also use another Windows Host to manage my secure email (TLS) and my PushOver messages (HTTPS). Running secure communications is a lot easier from Windows/PowerShell than native ESP and the ESP units just let the Windows Host send the alerts.
Not sure where this will end, but anyway it was fun to learn and build the prototype. I've used PowerShell a lot before, but now its even more easy to run and schedule scripts.
The rules engine will support some basic ESPEasy commands but i can also directly run native PowerShell from the rules engine like this:
On webPrint do
  webPrint
  webPrint Role: Hyper-V host
  webPrint <br>VM States:
  webPrintcall Get-VM | where {$_.state -ne "Off"} | select name,state | ConvertTo-HTML -head ""
  webPrint <table>
  webPrint <tr><td>DC19<td><a class="button-link" href="/?group=windows&cmd=event suspendVM=DC19">Pause</a>
  webPrint <td><a class="button-link" href="/?group=windows&cmd=event resumeVM=DC19">Resume</a>
  webPrint <td><a class="button-link" href="/?group=windows&cmd=event startVM=DC19">Start</a>
  webPrint <td><a class="button-link" href="/?group=windows&cmd=event shutdownVM=DC19">Stop</a>
  webPrint <tr><td>SP19<td><a class="button-link" href="/?group=windows&cmd=event suspendVM=SP19">Pause</a>
  webPrint <td><a class="button-link" href="/?group=windows&cmd=event resumeVM=SP19">Resume</a>
  webPrint <td><a class="button-link" href="/?group=windows&cmd=event startVM=SP19">Start</a>
  webPrint <td><a class="button-link" href="/?group=windows&cmd=event shutdownVM=SP19">Stop</a>
On SuspendVM do
  call suspend-vm -name %eventpayload%
On ResumeVM do
  call resume-vm -name %eventpayload%
On StartVM do
  call start-vm -name %eventpayload%
On ShutdownVM do
  call stop-vm -name %eventpayload%
For now, i just call it "WindowsEasy" ;)
Re: "WindowsEasy"
#2 Post by TD-er » 18 Jan 2024, 15:15
What p2p ID did you use, so I can add "Windows" to the ESPEasy code base :)
Re: "WindowsEasy"
#3 Post by TD-er » 18 Jan 2024, 15:17
Oh and did you notice I have encoded the build date into the "ESPEasy version" as is being sent via the p2p node info?
See: https://github.com/letscontrolit/ESPEas ... py#L13-L17
Re: "WindowsEasy"
#4 Post by Ath » 18 Jan 2024, 17:32
:geek:
martinus
Re: "WindowsEasy"
#5 Post by martinus » 04 Feb 2024, 14:19
TD-er wrote: 18 Jan 2024, 15:15 What p2p ID did you use, so I can add "Windows" to the ESPEasy code base :)
I'm using 255 currently, just not to interfere for sure. Not that likely that any other will find a usecase for "WindowsEasy" i guess...
