Problem with ultrasonic Sensor JSN-SR04T
I have a problem with the ultrasonic sensor JSN-SR04T: It should measure the water level in a cistern. Basically, that works very well. The values are delivered cleanly to my server every 60 seconds. However, the value freezes again and again if it measures the same or a similar distance longer. He then stays e.g. hang at 21 cm and the value changes only when I take it out of the cistern and e. change to 40 cm. Does anyone have an idea what it can be? I have the sensor with the parameters "Position - HC-SR04, RCW-0001, etc." integrated via ESpeasy.
Re: Problem with ultrasonic Sensor JSN-SR04T
I have the same problem.
Software: ESP Easy Mega, Git Build: mega-20211224_f162ebf
Controller: ESP-01S
Sensor: JSN-SR04T / AJ-SR04M
Could you solve the problem?
kind regards
Markus
Controller: ESP-01S
kind regards
Markus
- ESP01_JSN-SR04T.jpg (71.34 KiB) Viewed 22449 times
Hello Markus,
did you solve your problem? I'm wondering, there is a difference between the sensor in the device list HS-SR04 to your sensor JSN-SR04T? Did you also note that the output signal of the sensor is 5V and you have to reduce it to 3,3V?
Ingo
Ingo
Try this simple solution
Andrzej
Andrzej
- IMG-20210616-WA0006.jpeg (1.08 MiB) Viewed 20642 times
Hello Andrzej,
good idea! How did you connect the JSN-SR04T to the ESP? Did you use any converter for the Signal for 5V to 3,3V?
Thanks and best Regards!
The documentation for P013 has a link to the Level-converter page that actually has the schematics for wiring up a HC-SR04 ultrasonic sensor...
I have been using the JSN-SR04T (waterproof version) with a 3.3V supply voltage for several years now. It should actually work with 3-5V.
As usual with some devices, 'it depends'. The HC-SR01 I have here won't properly work with 3.3V..., so, YMMV
Users browsing this forum: Google [Bot] and 45 guests
